Antenna grinding noise
Old Jul 25, 2012 | 04:27 PM
holymoly's Avatar
My 98 Max, when I turn off the radio, there is a loud grinding noise from the antenna even after the mast has gone down completely.
Been awhile since I coated the mast with dry graphite, read that somewhere, but even after that, the same grinding remains.
A search here only returned these comments?
Perhaps need to change mast a new one for $5?
http://forums.maxima.org/4th-generat...a-problem.html
Old Jul 25, 2012 | 08:25 PM
asand1's Avatar
Yes, the last couple of teeth are worn off the rope gear and the motor continues spinning because it does not sense the normal resistance required to shut it off.
Old Jul 26, 2012 | 01:01 AM
99maxwell's Avatar
I have the same problem withmine, except the motor doesn't continue after the mast is fully down. But it is a pretty irritating sound. anyway to fix it? I spayed a lot of oil on it but that didn't seem to work.
Old Jul 26, 2012 | 08:19 AM
holymoly's Avatar
$74 for mast from the dealer.
Is it difficult to get one off a max in junk yard?
Old Jul 26, 2012 | 10:04 AM
asand1's Avatar
Don't bother with used on this, the rope gear gets brittle and comes apart over time. This has worked for me for the last 2 years.
http://www.ebay.com/itm/NEW-Nissan-M...=mtr#vi-ilComp
Old Jul 26, 2012 | 11:38 AM
holymoly's Avatar
Just ordered.
Thanks!
Old Jul 26, 2012 | 11:42 AM
Quickywd01's Avatar
http://www.ebay.com/itm/89-99-Nissan...f14d50&vxp=mtr
Old Jul 26, 2012 | 12:50 PM
asand1's Avatar
Why would you install that? He just needs a mast, and that looks like an aftermarket POS.
Old Aug 2, 2012 | 02:52 PM
holymoly's Avatar
Wow, delivered to north of the border in just 7 days.
The Haines manual recommends two people to change mast.
True?
Old Aug 3, 2012 | 06:47 AM
Trini Boom's Avatar
They just don't like you. Replaced mine two weeks ago and it was $36 from dealer.
Old Aug 3, 2012 | 07:46 AM
holymoly's Avatar
Canadian dealer, not only me they just don't like.
Old Aug 3, 2012 | 01:00 PM
DBear's Avatar
[The Haines manual recommends two people to change mast.
True?[/QUOTE]
Pretty much, yeah. You need one person to feed the new mast down into the antenna while the other turns the radio off. It can take you a few tries to get the teeth lined up right.
Old Aug 4, 2012 | 07:45 AM
holymoly's Avatar
Here's a youtube video albeit on a Honda, already posted in this forum, and I wish it was so simple
Old Aug 4, 2012 | 10:02 AM
asand1's Avatar
Mine was this easy. You don't need two people. Remove the nut with needle- nosed pliers inserted into the slots. Turn the ignition and radio on and run back there to pull. After the old one is removed, turn the ignition off and the antenna motor will reverse. It will run indefinitly so you have plenty of time to insert the rope gear, guiding the outer sleeve of the new mast into its hole, then replace the nut.
Old Aug 6, 2012 | 07:37 AM
bobflood's Avatar
Unfortunately, it's not always this easy. Much depends on where/how the nylon part breaks inside the motor housing. On mine, there were multiple broken pieces, so everything would not feed up the hole. I ended up having to take out the whole assembly and disassemble it so I could clean out all the broken pieces.
Old Aug 6, 2012 | 07:49 AM
holymoly's Avatar
Reading from the Antennamastsrus.com site, if it currently grinds after the old mast goes down, I push it, the guide that holds the cable next to the gear is bad.
http://antennamastsrus.com/Instructions%20Mast.htm
Old Aug 7, 2012 | 05:48 PM
holymoly's Avatar
OK the old mast wouldn't come out when I powered the radio, so I took out the whole assembly opened it up and uncoil the chain and the trouble is I still can't extract the old mast from the assembly.
Keep trying?
I went to a local auto parts store and they have generic antenna with cable connector thereby bypassing the power motor. But looks like its round shape not compatible with the oval opening on the fender.
Suggestions are welcome at this point.
Old Aug 8, 2012 | 06:08 AM
Trini Boom's Avatar
Is the mast still coming out partially? What you have to do is throw in some penetrating oil and then use a vise grip in good condition and grab it right two inches away from fender and pull very hard.
Old Aug 8, 2012 | 03:52 PM
holymoly's Avatar
well it snapped about 1/2" from the base, no grip at all.
The E2 antenna available at local shops seems poor fit.
Found this stubby at http://cgi.ebay.ca/ws/eBayISAPI.dll?...#ht_500wt_1414
not sure it includes wiring.
The junk yard is another option.
Old Aug 8, 2012 | 06:15 PM
holymoly's Avatar
ooh, $60 is the cheapest used.
Seems to install the E2 I need to enlarge the opening, its too oval.
Metal file?
Old Aug 8, 2012 | 06:35 PM
GGENIUS's Avatar
unplug that ****. who listens to the regular radio?? lolzzz
Old Aug 8, 2012 | 06:59 PM
zack97GLE's Avatar
+1 who uses an antenna.
Old Aug 8, 2012 | 07:13 PM
GGENIUS's Avatar
****** stuck listenin to MMR like ****in boring *** middle aged men.
Old Aug 9, 2012 | 05:33 AM
holymoly's Avatar
+2
Old Aug 9, 2012 | 05:17 PM
holymoly's Avatar
The nissan commector is like a cat5 wire connector for a PC. Is there an adapter to the universal antenna connector?
Old Aug 11, 2012 | 11:08 AM
holymoly's Avatar
I didn't plan, all I wanted was a functional antenna, the easiest solution was disconnect the power motor.
Now I can't put the antenna back in place. This black cover is not designed to fit in the silver receptacle.
I butts the lip in the interior.
Old Aug 11, 2012 | 04:26 PM
holymoly's Avatar
Duh, the silver part goes under the fender, only the black piece with the antenna, what's left of it.
user 11122324
42
Jul 18, 2022 03:35 PM
chisam14
Nov 6, 2018 08:56 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
