High RPM's at higher gears
Old Jan 7, 2002 | 05:15 PM
maxedout95's Avatar
What can I do or what it is the reason on why my RPM's are so high in like the 3rd 4th and 5th gear they're about 600-700 over what a automatic is and I have a 5 speed should they be lower ? why is that ?
Old Jan 7, 2002 | 06:39 PM
MAXEJA's Avatar
im not an expert but i think overdrive might have something to do with it, plus just the gear ratios.
Old Jan 7, 2002 | 06:46 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: High RPM's at higher gears
your correct.. me and nismo2020 were discussing this looking at videos the otehr night. my 97 se auto revs lower at high speeds in 4th/OD than a stock 97 se 5 speed at high speeds in 5th
I was thinking that since we have 1 less gear the gear ratio, like maxej said , is so different. They have to be different obviously , but the auto should go the same speed as a 5-speed with 1 less gear.
so the gear raitos need to be different. example a 5-speed changes to 2nd before and auto changes to 2nd
Old Jan 8, 2002 | 07:59 AM
iwannabmw's Avatar
Re: Re: High RPM's at higher gears
Nissan didn't make the overall gear ratios the same with the auto and the 5speed, it doesn't matter how many gears you have, the cars have totally different personalities. The gear ratios were made shorter in the 5 speed so the car would lean more towards performance, while the auto was designed a little more for economy. This is why a stock 5 speed will spank a stock auto, but on the highway the auto is slightly more efficient.
Old Jan 10, 2002 | 08:08 AM
iwannabmw's Avatar
These might have been posted before, but I can't remember, so here they are:
4th Gen Auto
1st Gear = 2.79
2nd Gear = 1.51
3rd Gear = 1.00
4th Gear = .69
Final Drive Ratio = 3.62
4th Gen 5 Speed
1st Gear = 3.29
2nd Gear = 1.85
3rd Gear = 1.27
4th Gear = .95
5th Gear = .80
Final Drive Ratio = 3.82
Both sets of numbers came from different issues of Car and Driver.
Old Jan 10, 2002 | 08:17 AM
Bags's Avatar
4th Gen Auto
1st Gear = 2.79
2nd Gear = 1.51
3rd Gear = 1.00
4th Gear = .69
4th Gen 5 Speed
1st Gear = 3.29
2nd Gear = 1.85
3rd Gear = 1.27
4th Gear = .95
5th Gear = .80
ahh i thought the final drive ratio was the same. well again i learn something from maxima.org thank you
Old Jan 10, 2002 | 01:51 PM
maxedout95's Avatar
Thanx for the info bro it really made me look at this a different way I couldn't understand why it was like that cuz I thought the ratios were pretty close and that 5spd was a little bit smaller but now I know better thanx for your search and input
Old Jan 10, 2002 | 03:52 PM
MAXEJA's Avatar
i think we all learned something here... hmmm 5 speed way to go!
Old Jan 10, 2002 | 06:47 PM
iwannabmw's Avatar
Yeah, until I just looked at the numbers side by side I didn't know they were THAT different either. Kinda makes you wish they built more 5 speeds.
Mar 12, 2020 12:06 AM
slowlifer
Sep 8, 2015 05:53 AM
dcardello
Sep 3, 2015 11:44 PM
