Starter
Old Jan 7, 2002 | 05:52 PM
PRPmax's Avatar
Starter
How hard is it to swap out starters.. It's just about that time with mines. Very annoying grinding noise upon start up's. I've priced checked a few like
$228.51 $75.00(Core) BOSCH - Rmfg. Starter, ALL Mdls.
$112.77 $90.00(Core) AIM - Rmfg. Starter, ALL 3.0L V6 Mdls. (1.4KW)
What do you guys think?
Thanks,
Nelson
Old Jan 7, 2002 | 06:00 PM
KWheelzSB's Avatar
Re: Starter
Thanks,
Nelson
If you can turn a wrench, it's a piece of cake. Search for "starter" you will find all sorts of how-to's, etc.
Make sure that when you shop for starters, you get the newer, upgraded 10-tooth version. Not the old 8-tooth. The motor was upgraded after '96 due to premature failures, but many auto parts-places still sell the older 8-tooth version.
Old Jan 7, 2002 | 06:01 PM
BlancMax's Avatar
If I remember correctly it's pretty freakin hard. I might be thinking of the altenator though. Try a search it seems like for one or the other you might have to remove the radiator or something else. I'm just not sure.
Old Jan 7, 2002 | 06:11 PM
BlancMax's Avatar
my mistake I must of been thinking of something else.
Old Jan 7, 2002 | 06:12 PM
KWheelzSB's Avatar
Yeah, you could be referring to the alternator. The starter motor only requires that some of the intake plumbing be removed to gain access. Other than that, it's right on top of the bell housing - easy access. It shouldn't take more than 30-40 mins. start2finish.
Old Jan 7, 2002 | 06:21 PM
Mishmosh's Avatar
http://forums.maxima.org/showthread....hlight=starter
Old Jan 7, 2002 | 06:36 PM
PRPmax's Avatar
Thanks guys.. This will have to be my weekend project.
Old Jan 7, 2002 | 06:52 PM
clee130's Avatar
Just one day should be good enough.
It's a simple job, just make sure you have all the tools ready before you get started.
The bolts might be on pretty tight though.
Old Jan 8, 2002 | 12:39 AM
95emeraldgxe's Avatar
i love yor RWD maxima clee -
Old Jan 9, 2002 | 01:51 PM
matty's Avatar
Will the 10 tooth new version starter fit my 96'se ??
Old Jan 9, 2002 | 01:57 PM
Mishmosh's Avatar
Yes. Definitely get the 10 tooth version. They changed it for a reason...
Old Jan 9, 2002 | 02:18 PM
SuDZ's Avatar
Start spraying some rust eater on the day before. It should loosen them up a little for you.
SuDZ
Old Jan 9, 2002 | 02:23 PM
hlh0501's Avatar
15minutes, tops
I changed mine out.. 10tooth version and most places give a lifetime warranty on them so now I can start the heck out of my car haha...
alternator is a PAIN though...
Old Jan 9, 2002 | 02:37 PM
PRPmax's Avatar
SuDZ
No snow to rust up the ride or the salt they lay down for the ice. So they are rust free.
Old Jan 9, 2002 | 03:03 PM
Bags's Avatar
VG Ridah's Biatch Hoe
hey i have the FSM if you need it. Just email me or whatever and it's yours
Old Jan 9, 2002 | 04:14 PM
PRPmax's Avatar
Hell Yeah!
Old Jan 9, 2002 | 04:38 PM
maxedout95's Avatar
Re: Starter
All I got to say that unless you got a lot of time patience and don't mind getting cut up don't bother
Old Jan 9, 2002 | 04:43 PM
PRPmax's Avatar
Re: Re: Starter
The maxima had its way with you?
Old Jan 9, 2002 | 05:03 PM
maxedout95's Avatar
Re: Re: Re: Starter
YEP
Old Jan 9, 2002 | 05:26 PM
Mishmosh's Avatar
Re: Re: Re: Re: Starter
If you have a CAI or pop and removed the stock intake hardware, you should have enough room to get the job done without much hassle. The rear bolt is pretty tough though...
Old Jan 9, 2002 | 08:14 PM
PRPmax's Avatar
Maybe I haven't looked enough around here. But i'm not able to find a 10tooth version starter? Must have been a new guy working at NOPI, But he didn't know squat about cars. I thought you had to know at least the basics when working there, Oh wells, Where did you guys get yours from?
Old Jan 9, 2002 | 09:53 PM
mikey62681's Avatar
recent starter break down
The starter in my 95 max just went out on me, I went to Nissan and they wanted $350.00 to put a new one in (labor included). A local part store want $169.00 plus a $65.00 core.I decided to go to a local starter shop, I pulled it over ther at 8:00 in the morning and they had it done and back to be by 1:00 that afternoon for $80.00, my advice look up your local listing for a starter rebbuild shop. Give it a shot.
thanks Mike
Old Jan 9, 2002 | 10:01 PM
ny96max's Avatar
I just did mine 5 days ago
You will def need a 17mm deep socket with 6" extention and a huge-a$$ breaker bar for the back bolt!! I used a 4ft long 2" round steel pipe to break the bolt free(oh and you will have to remove your upper intake tubing to make this work easier)Its almost welded on there from the factory. after i got that free(20min), took another 10min to finish.
enjoy!
Anthony
paid: $124 +$70 core deposit
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
