Camry and Honda wheels interchangeable ??
Old Jan 7, 2002 | 08:04 PM
puch's Avatar
Hi,
Doesn't anyone know if you can use the wheels from a Camry or an Acura TL on the Maxima ? I mean they both have the same bolt pattern 5x114.3 and I think the offset is also the same if not very close then ? Anyone try it before ??
thx,
Jeff
Old Jan 7, 2002 | 08:06 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Re: Camry and Honda wheels interchangeable ??
Originally posted by puch
Hi,
thx,
Jeff
That is the right bolt pattern. Try to keep the offset somewhere between 38? and 42mm. But i'm sure it'll fit.
Old Jan 7, 2002 | 08:28 PM
puch's Avatar
Re: Re: Camry and Honda wheels interchangeable ??
Forgot to ask about the hub size diameter. I know that the Nissan wheels are hub centric ? Do other wheels hub hole are the same too ?
thx,
Jeff
Old Jan 7, 2002 | 09:11 PM
Ginuwin3112
What's an offset and how do u measure it??
Old Jan 7, 2002 | 09:29 PM
RedMax95's Avatar
the wheels say it, its the distance from the beginning of the rim to the place it is attached, im pretty sure thats right
Old Jan 7, 2002 | 10:31 PM
_DRU_'s Avatar
Re: Re: Re: Camry and Honda wheels interchangeable ??
thx,
Jeff
the hub diameter on the acura might be a bit too small. the rims off a V6 Accord and Prelude are too small by just a hair.
Old Jan 8, 2002 | 10:38 AM
Weasel's Avatar
The TL and Accord use a much higher offset range than the Maxima, check on this before you buy.
Old Jan 8, 2002 | 11:22 PM
ericdwong's Avatar
The Camry wheels will probably fit. They have a lower offset then the Maxima wheels do, so they may have a tendency to stick out some. Their bolt pattern is the same however. I tried fitting my 97 maxima 16" SE star rims on my mom's 98 camry and the spokes wouldnt clear the brake calipers by less then 5 mm.
Old Jan 9, 2002 | 12:07 AM
Bman's Avatar
All Maximas (at least till '99 for sure) have 66.1mm centerbore, so make sure the other wheels are larger or they won't fit.
A few people have worried about this "hubcentric" thing, but some others have also just allowed the wheelnuts to hold up the wheel without any hub support ("lugcentric" according to Tirerack). This is for 3rd Gens which have tapered (conical) lugnuts (should be same though). I don't know which is right, but so far the lugcentric way guy's wheels haven't snapped off! Maybe someone can findout?
Also, here's the simplest definition of OFFSET: http://www.whalentire.com/faqs.cfm#offset It's measured from the center of the rim, so it's "universal" and doesn't depend on the rim width like "backspacing" does.
Old Jan 9, 2002 | 01:14 PM
Ginuwin3112
Thanx man ...
jsmith24
Feb 1, 2016 12:35 AM
markevans999
Oct 25, 2015 08:27 AM
f.matejaiii
Sep 21, 2015 12:09 PM
crazyespn
Sep 3, 2015 01:30 PM
