rear valve cover?
Old Sep 3, 2012 | 12:11 PM
maxinout93's Avatar
rear valve cover?
does anyone have a pic of the rear valve cover or the part number. I'm askin because I just need the rear near the firewall not the whole set. want to fix it asap thank you!! its on a 95 max
Old Sep 3, 2012 | 01:35 PM
SVI30's Avatar
You need the valve cover or the valve cover gaskets?
Old Sep 3, 2012 | 06:12 PM
maxinout93's Avatar
my bad, yea the valve cover gasket and tube seals
Old Sep 3, 2012 | 06:32 PM
96WhiteMaxima's Avatar
FEL-PRO Part Number VS50494R. You're welcome
MaxEdit: I'm sorry I didn't see you only needed the rear, but you might as well change the front anyway since you're gonna throw all the effort into taking out the rear.
Old Sep 3, 2012 | 11:50 PM
maxinout93's Avatar
well I was jus gonna do the rear since its the one leaking and leave the front alone til it starts to leak since its easier to get to
Old Sep 4, 2012 | 05:54 AM
renots's Avatar
For the few extra bucks an 30 more minutes of time I would do the front also. Also get the guide tube seals too, rockauto has the complete valve cover gasket set including guide tube seals for $37 bucks made by felpro.
Old Sep 4, 2012 | 07:06 AM
dwapenyi's Avatar
May as well do everything as recommened by renots (front, rear valve cover and spark plug tube seals) once and done.
Hell, I would add knock sensor, IACV, EGR, and throttle body cleaning too. All those items are way easier to access with the UIM off
DW
EDITED because yI in-correctly specfied to remove the UIM to work on the front valve cover.
Old Sep 4, 2012 | 07:41 AM
BenL's Avatar
Originally Posted by dwapenyi
[...] keep in mind that in both cases the upper intake manifold has to come off [...]
False.
Old Sep 4, 2012 | 09:14 AM
dwapenyi's Avatar
Originally Posted by BenL
False.
You know what you're right m bad. Brain fart.
Old Sep 4, 2012 | 09:20 AM
ShocknAwe's Avatar
make sure you liquid gasket those corners too
Old Sep 4, 2012 | 10:28 AM
maxinout93's Avatar
ok guys thanks for the advice. I may as well do the gaskets and tube seals at the same time, I've also gotta do the knock sensor also as well as a change a fuel injector right beneath the intake manifold. it will b a good project for me lol.
Old Sep 4, 2012 | 04:09 PM
Rob_0126's Avatar
I might add that it is time consuming. I did mine and it took all day(because I didnt seat the intake manifold gasket correctly and had to take it off after bolting everything back together).
So it should take half a day if you take your time and clean the intake manifold.
Something I also learned:
Toyota makes the best rtv black sealant, that I know of. Use to cost $10 a tube, and it's well worth the bucks.
Matt93SE
Apr 8, 2018 09:23 AM
Huttig2009
Sep 25, 2015 03:31 PM
Maximeltman
Aug 31, 2015 01:01 PM
maxipower
Aug 21, 2015 11:10 AM
Nintensity
Aug 13, 2015 05:41 PM
