Security
Old Sep 6, 2012 | 01:04 PM
Spencer5556's Avatar
Security
Had my car stolen and finally got it recovered. I want to prevent this from happening again.
What are some good suggestions for security on a 98 maxima? I bought the club but I know that is just a minor solution.
What kinda of alarm would you suggest? And how pricey are they?
Any other info would be great!
Old Sep 6, 2012 | 01:18 PM
Amerikaner83's Avatar
Thieves will take your car if they want to bad enough.
Club is ok, so are alarms. Most people though just disregard alarms when they hear them since they're so common.
It's been discussed here before, but I don't remember where...I think the consensus was a kill-switch to the fuel pump relay that as hard-wired somewhere...
basically, turn car off, and flick the switch. This disables the fuel pump from pumping, and car won't start. Flip the switch and fuel pump is operational again. The key was to put the switch somewhere that it is NOT obvious what it is.
Old Sep 6, 2012 | 01:19 PM
Pull fuses before parking the car.
Old Sep 6, 2012 | 02:00 PM
How much is it to do a kill switch?
Currently I am just pulling the fuse, but they could just take my radio fuse and put it in the fuel pump fuse spot
Old Sep 6, 2012 | 02:13 PM
that depends on how you want to wire it.
Besides, will they KNOW which fuse to pull to put in tthe place?
Old Sep 6, 2012 | 02:22 PM
I'll deff have to remove the diagram haha but then they won't unless they own a 4th gen, I'll remove it tonight, and just put it somewhere safe, I think that's my best bet, fuse and a club.
Old Sep 6, 2012 | 03:51 PM
Jayson89NYC's Avatar
i have seen maximas with boot locks on i guess that will work
Old Sep 6, 2012 | 04:14 PM
ShocknAwe's Avatar
Quick connect wheel hub lol and take the steering wheel with you. A kill switch is a good idea as well and you can just do it for the negative battery cable
Old Sep 6, 2012 | 05:11 PM
deloa84's Avatar
Cant you do a kill switch to the cam shaft sensor? The car will crank and crank all day but it will never start...
Old Sep 6, 2012 | 06:31 PM
There are a few more fuses you can pull.
Old Sep 6, 2012 | 06:33 PM
RA121625's Avatar
I believe its only the primary crank sensor that will prevent the car from starting.
Viper makes pretty cool alarms that notify you on your phone when someone trips the alarm.
Old Sep 6, 2012 | 06:42 PM
tothemax2003's Avatar
i have a beeper alarm and a brake lock
Old Sep 6, 2012 | 06:43 PM
Shift_A32B's Avatar
Quick release steering wheel
Old Sep 6, 2012 | 06:44 PM
maxgtr2000's Avatar
KH3 by popular demand
Yes there are different fuses you can pull, relays, to disable the car. Kill switches can be put on whatever wires to disable the car. Don't reveal what you actually do to your car because theives probably troll on here. An alarm is only 1 layer of security, if you have different layers it will make it harder to steal. Think about if your alarm was damaged or disabled what other way can prevent theft, an alarm isn't everything but it helps. My alarm malfunctioned but another layer of security saved the day.
Old Sep 6, 2012 | 06:50 PM
styliztik's Avatar
I made my own kill switch. I can flip it with my foot when I get in without too much obvious work.
Old Sep 6, 2012 | 08:52 PM
ibracey's Avatar
the kill switch way could be cool but which wire to hook it to??
Old Sep 6, 2012 | 09:18 PM
How much is the stuff for a kill switch?
Old Sep 6, 2012 | 09:19 PM
styliztik's Avatar
I hooked mine to the ignition one under the dash. IIRC, it's one of the thicker wires down there that's black with a white stripe. I used a toggle switch.
Old Sep 6, 2012 | 11:50 PM
deloa84's Avatar
Funny you should mention toggle switches. My brother who works at RadioShack came home with like 30some toggle switches, resistors, RCAs,etc that they were gonna toss out because the were "discontinued" packages. I would say it's pretty darn close to $100 dollars in merchandise. Half easily being toggle switches...
Old Sep 7, 2012 | 08:19 PM
stromm's Avatar
Isn't that really hard to do while driving?
Old Sep 7, 2012 | 08:35 PM
max ride 41's Avatar
move????
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
gustavison
Oct 4, 2015 06:50 PM
Junebug1701
Sep 25, 2015 01:54 PM
