antenna
Old Jan 7, 2002 | 11:50 PM
jiggity1226's Avatar
antenna
I drove my 97 maxima through the car wash with the antenna on. As a result the antenna is broke off. IS there anywhere on the internet that I could get a replacement antenna
Old Jan 8, 2002 | 12:22 AM
95emeraldgxe's Avatar
eh - do u really need an antenna??? - well if u do..... u can get one for like 10 bucks from any performance store or www.installer.com/antenna/
Old Jan 8, 2002 | 05:37 AM
Mishmosh's Avatar
Re: antenna
I recently did the same thing... although I backed into my garage with the door not fully up. It was sad to see. In any case, more than likely, you can just replace the telescopic mast and not the whole unit. The mast is around $30 from the dealer I think but the whole unit is really expensive. I don't know what it includes but there are two wire harnesses attached to the motor unit. When I disconnect the larger one, the remote keyless entry no longer works! As I really just listen to mP3's in the car, I think I'm going to bag replacing the mast. In any case, I followed the instructions in Haynes and couldn't get the mast portion to come out. It almost seemed like Haynes was talking about a different unit as the bezel can not be taken out by a standard antennna bezel remover tool.
As long as the rope and motor are good, the dealer can install the mast for around $60 or so. That would be your best bet.
Old Jan 8, 2002 | 10:40 AM
ptatohed's Avatar
Licensed to Spell
:o)
Shave it baby, shave it!
Old Jan 8, 2002 | 10:43 AM
Max4Speed's Avatar
www.autotalk.com
http://cgi.ebay.com/ebaymotors/aw-cg...225412&r=0&t=0
Old Jan 8, 2002 | 11:02 AM
guitaraus's Avatar
I agree with ptatohed - shave that ****!
Old Jan 8, 2002 | 11:04 AM
Max4Speed's Avatar
www.autotalk.com
give the $$ to him?
Old Jan 8, 2002 | 12:45 PM
SuDZ's Avatar
If you shave the antenna will the radio still get stations?
Old Jan 9, 2002 | 08:55 PM
ptatohed's Avatar
Licensed to Spell
:o)
Yes and no Sudz. What I did was shaved mine and then added a Fuba antenna (45^ roof mounted VW/Audi antenna). But there was some downtime between the 'shave' and the Fuba. If you have the Bose package like I do, there is an antenna in the rear windhield. It's called a dual diversity antenna. The way it works stock is the radio will choose the better of the two receptions (mast antenna and windhield antenna). So when I had my mast antenna shaved , I could still hear the radio from the windshield antenna. And I actually didn't even sense a loss in reception either... for FM that is. AM almost completely disappeared. Not sure why. ?? Now with the Fuba, of course I get it all, AM/FM. And there are antennas you can buy that hide in the pillars too. Anyway, hope I answered your q.
Old Jan 9, 2002 | 09:27 PM
pawn's Avatar
XM radio baby!
Old Jan 9, 2002 | 10:12 PM
ny96max's Avatar
Originally posted by pawn
XM radio baby!
XM is good, but not for $10 a month on top of all my bills :/
Old Jan 9, 2002 | 10:35 PM
you guys are nuts! - shaving the antenna is mucho dinero......i say paint it the body color, disconnect the cable and then get one integrated into yor rear windshield
Old Jan 9, 2002 | 11:11 PM
ptatohed's Avatar
Licensed to Spell
:o)
I HAAAAAAAAAAAAATE things that are unnsymmetrical. I am a symmetrical nut! That's why the keyhole and exhaust had to go (now if I can just think of something for that pesky gas cap...) as well. I also hate "growths" and I also hate things that aren't body color. So for all those reasons, the antenna had to go. No matter the price.
Anyway, I'm not following you. Why would you paint it body color and disconnect the cable as opposed to painting it body color and leaving the cable attached?
Old Jan 10, 2002 | 09:15 AM
pawn's Avatar
well....i don't have YOUR bills
Old Jan 10, 2002 | 10:03 AM
99sleeper's Avatar
Go to pep-boys, $14 for the mast..I did the same thing, the only ***** when putting it in is getting the little white teeth to catch inside the power unit. $14 and 10 min.
Old Jan 10, 2002 | 12:14 PM
Mishmosh's Avatar
Care to delineate a brief How2? I got the antenna bezel off. I turn the radio on and help it retract up. Now what? The mast doesn't just pull out does it?--cause mine doesn't.
Old Jan 10, 2002 | 01:04 PM
99sleeper's Avatar
Well see I got a little ****ed off when it happened and just ripped the thing out...So after I screwed the little chrome cap off and removed the nub that was left, I just had a buddy sitting in the car turn the radio on so that the motor started turning, feed the white plastic strip in with the teeth towards the front of the car(I think). It took a few trys to get it started, but once it took it I just screwed the cap back on, and I had a radio again..Sorry I couldn't be of more help...
Old Jan 10, 2002 | 01:07 PM
99sleeper's Avatar
Actually I had my buddy turn the radio on, then off..woops...
MikesChevelle
Nov 23, 2024 11:17 AM
chisam14
Nov 6, 2018 08:56 PM
DBear
Sep 14, 2015 08:33 PM
Violator
Sep 9, 2015 10:14 AM
98nismomax
Aug 13, 2015 12:44 PM
