4th gen maxima rough idle when at complete stop and in neutral
Old Sep 13, 2012 | 05:36 AM
Johnny1251's Avatar
I have 95 maxima 5 speed and recently I replace my fuel injectors and when I went to start it my rpm's drop below 700 and the motor vibrated and eventually dies it only does it if car is in neutral and at a compleote stop after I seen it doing all that I took it apart again and made sure everything was hooked up right and and still have same
problem
I would appreciate any help
Old Sep 13, 2012 | 06:22 AM
njmaxseltd's Avatar
A little more history? Why did you replace the fuel injectors? What was going on prior to that?
Old Sep 13, 2012 | 07:25 AM
Johnny1251's Avatar
It had a bad fuel injector and would buck while running but it wasq between 2500-4500 rpm
Old Sep 13, 2012 | 09:26 AM
njmaxseltd's Avatar
Is that buck now gone? Usually the buck points to a bad coil pack on our cars. The fuel injectors rarely give us any problem.
Clean and check the IACV and TB. Did the car throw codes prior to the FI replacement and if so what were they? Any codes stored now?
Lakersallday24
Nov 7, 2024 07:31 PM
CRizz
41
Jun 7, 2021 05:42 AM
Lakersallday24
Jun 16, 2019 01:35 AM
morteljc
Oct 19, 2015 10:47 AM
