ebay wheel bearing replacement
Old Sep 14, 2012 | 11:46 AM
asand1's Avatar
ebay WJB wheel bearing replacement
My right front wheel bearing is bad. Started making a light grinding noise, like a cyclic scraping, at ~10 mph, and a louder grinding while making a left hand turn. Ordered a bearing and two seals for $34.00 from ebay. Will update after the job is done.
http://www.ebay.com/itm/Nissan-Maxim...sories&vxp=mtr
Old Sep 14, 2012 | 01:33 PM
Why didn't you just buy a replacement hub for a little more?
Old Sep 14, 2012 | 02:07 PM
asand1's Avatar
AFAIK you cant buy a FRONT hub bearing assembly, because you have to press the bearing into the knuckle before pressing in the hub.
Old Sep 14, 2012 | 08:16 PM
nismomaxgtr18's Avatar
Brand new wheel bearing from Nissan is $50.
Old Sep 14, 2012 | 08:56 PM
Cebby's Avatar
I'm doing this right now - bought Timken bearings & new seals. Not something I want to take apart to do again any time soon...
Old Sep 14, 2012 | 09:22 PM
wxm's Avatar
wxm
It was definitely a painful job to separate the bearing from the hub. IMHO, the labor is way more than the parts worth. I would get OEM or Timken.
Old Sep 17, 2012 | 11:25 AM
bhunter's Avatar
After owning two 92's, a 93 and a 99 maxima I learned to always, always put a new hub in with the bearing. You don't have to separate the half of the bearing stuck on the old hub and you know a worn hub won't make you do this job twice.
Old Sep 17, 2012 | 11:50 AM
MAXIMA_STYLE's Avatar
Replacement knuckle and bearing ftw... lol
Old Sep 18, 2012 | 09:52 PM
asand1's Avatar
WJB bearings came in today. Made in china, no surprise there.
Old Sep 18, 2012 | 10:01 PM
Cebby's Avatar
Are you doing this job yourself? I just did this and took pics.
Old Sep 18, 2012 | 10:03 PM
asand1's Avatar
Yes, I will be. I need to call around and find someone to let me use their hydraulic press. Ive done this many times working for various shops.
Old Sep 18, 2012 | 10:27 PM
Cebby's Avatar
Then the pressing part is easy for you (I might put up a thread for others anyway)
Only thing I will caution you on is the ABS sensors. Do NOT try to remove them from the knuckle. There are plugs inside the engine bay to disconnect them.
I found an old thread that said they'd come right out of the knuckle (not the case on my 16 year old Max). Pried a hair too hard and cracked the first one.
Old Sep 18, 2012 | 11:22 PM
asand1's Avatar
No ABS here, but good point.
Old Sep 22, 2012 | 09:48 PM
asand1's Avatar
I started the install yesterday after work. Originally I was going to use 3/4" all thread and heavy washers. The washers started to bend and the bearing wouldn't budge so I hade to drive the old bearing out with a 3lb shop hammer and drift. I drove the new bearing in with the old outer race and shop hammer again. The hardest part was keeping the pre-lubed bearing free of contamination. I ran into a snag when it came time to torque the axle nuts and I realized I never did torque either side after rebooting the outer CV joints some years ago.
Read here how I torqued them to 200ft/lb with a 150ft/lb wrench.
http://forums.maxima.org/garage-work...-capacity.html
Old Sep 28, 2012 | 09:13 PM
asand1's Avatar
I'm at 279,624 miles now, about 230 Miles since replacing the bearing. The noise is now gone. I'll post later when I have a few more thousand miles on it.
homeyclaus
Sep 3, 2015 06:15 PM
stromm
Aug 27, 2015 04:13 PM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
