Broken Sway Bar End Link
Old Sep 15, 2012 | 03:42 PM
LILMAN's Avatar
After soaking them penitrant the bolt broke off at the bottom part of the end link. What options do i have to get the top nut off?
Old Sep 15, 2012 | 05:49 PM
nitromax's Avatar
is the nut turning? if not , turn & break that nut off, you may have to cut it off.
Old Sep 15, 2012 | 08:22 PM
LILMAN's Avatar
The whole thing spins. I was thinking of using a picklefork to pry it out but i don't know how far the threads go.
Old Sep 16, 2012 | 07:58 PM
2brosgixxer's Avatar
Why not just put a pair of vice grips on the link to keep it from spinning?
Old Sep 17, 2012 | 07:14 AM
M in KC's Avatar
I had to use a sawz-all on one of mine this weekend to remove it. These things can be a pita to remove. If you end up going this rute careful not to hack the LCA with the recip blade. I went with Moog's replacement links, almost double the cost of the low end link kits but they have a LT warranty so I will never be buying them again. In addition they were the only greaseable links I could find.
Old Sep 17, 2012 | 09:16 AM
99BlackMaxMS's Avatar
This is what I had to do on mine as the boot was already torn and the endlink kept popping out of the knuckle.
Stagnet04
Sep 14, 2015 11:28 PM
Hdnseek
Sep 9, 2015 05:55 AM
