Energy Suspension Question?
Old Jan 8, 2002 | 12:13 PM
jdmmax's Avatar
i just want to know if anyone has the Energy Suspension Front control
arm bushings. what is the difference in the handling and ride? if it is worth the money??
Old Jan 8, 2002 | 02:11 PM
ericdwong's Avatar
We don't have upper control arms like hondas do. We do however have lower control arms.
Old Jan 8, 2002 | 02:46 PM
benny's Avatar
Putting it on tomorrow, will let you know with my opinion
after I give it a spin.
Old Jan 8, 2002 | 03:37 PM
jdmmax's Avatar
koo
oh and are you putting them on yourself or professionally.
Old Jan 8, 2002 | 06:09 PM
benny's Avatar
got a friend who works at a garage, got access to a lift and
tools, going to help me with the install.
Old Jan 8, 2002 | 07:01 PM
jdmmax's Avatar
can you also let me know how easy or hard it is to install them ???
thanks
Old Jan 8, 2002 | 07:02 PM
SuDZ's Avatar
Is a lift needed or will a jack do?
SuDZ
Old Jan 8, 2002 | 07:19 PM
KWheelzSB's Avatar
SuDZ
I'm going to assume you meant that you plan to jack up your car & put it on JACK STANDS, not that you'll be crawling underneath with only the jack for support.
For those reading this, NEVER, EVER crawl under a car supported only by a jack. You risk being squashed like a grape if you do. . .
You should be able to do this job w/ jackstands, no problem.
Old Jan 9, 2002 | 11:29 AM
benny's Avatar
put the lower control arm bushings in, the steering feel is great.
the car feels more solid. more positive feedback. highly recommended.
now the bad news, not recommend for the DIY. The rubber in the control arm was a b!tch to remove, the large control arm bushing have to be cut off with a grinder. the pivot arm bushing have to use a torch to burn it off. my friend say this is a 1 1/2 hour job.
keep in mind, this was done on a lift, with all power tools.
let the pros handle this job.
can't wait to have some dry weather to try it out in the turns.
Old Jan 9, 2002 | 12:27 PM
jdmmax's Avatar
koo thanks oh did removing the control arm screw with your alighnment as far as you can tell?????
Old Jan 9, 2002 | 06:39 PM
benny's Avatar
I didn't feel any difference, but my friend said it would
only affect the toe in, toe out. I'll run it for awhile
and see if any changes. If it don't feel right I will get
an alignment.
Old Jan 9, 2002 | 10:14 PM
xHypex's Avatar
I've heard that the control arm bushings were a pain to put on, but how much do they cost? I'm probably going to lower my car this summer, but I was also considering the control arm bushings and/or engine mounts to reduce wheel hop. Did you buy the parts straight from Energy?
-hype
Old Jan 10, 2002 | 12:08 AM
jdmmax's Avatar
-hype
i can get them at my work. they told me like $40 because of employee discount. but i have to reference this price.
oh and thanks benny for the feed back !!!
Old Jan 10, 2002 | 01:18 AM
KWheelzSB's Avatar
an alignment.
You might not know until your tires start wearing funny. Your alignment can be out by an amount you can't feel, but by enough to cause adverse/premature tire-wear. As a general rule, you should get an alignment if you've disassembled any suspension components - unless you don't mind spending extra dough on tires.
Old Jan 10, 2002 | 10:24 AM
xHypex's Avatar
Thanks for the reply jdmmax, but that doesn't help me very much unless you want to buy me some bushings :P Is there an online retailer who sells the bushings? If there is I have yet to find them.
-hype
Old Jan 10, 2002 | 10:57 AM
roruiz's Avatar
-hype
try this place, I got mine here. www.suspension.com
Old Jan 10, 2002 | 11:22 AM
jdmmax's Avatar
buying my set today. just wondering are the parts black???
cause web site says 7-3111 and the part # on packages is G7-3111.
is it the same????
Old Jan 10, 2002 | 12:56 PM
roruiz's Avatar
is it the same????
you can get them in any color that energy suspension offers. I got the black because those are graphite impregnated. What ever color you get, make sure to use plenty of the water proof grease.
Old Jan 10, 2002 | 01:56 PM
KWheelzSB's Avatar
Sounds like a smart idea, since some people have reported "squeaking" after putting the red poly one's in. I'd probably choose function over fashion on this particular application, too.
"You're a pretty fart smella!"
(For those who don't know, the graphite-impregnated bushings are self-lubricating = less likely to squeak)
Old Jan 10, 2002 | 02:39 PM
jdmmax's Avatar
ok thank you
Old Jan 10, 2002 | 03:00 PM
jdmmax's Avatar
i just bought them
yay i just got my bushings.
Old Jan 12, 2002 | 02:57 AM
jdmmax's Avatar
Re: i just bought them
AAAARRRRRGGHGHHHHHH!!!!!!
they are a b!$@H to put on stupid stock bushings.
5 hours for one side absolutly terrible.
Old Jan 12, 2002 | 06:09 AM
KWheelzSB's Avatar
Re: Re: i just bought them
That sux man - it seems like the concensus on these is that it's a job best left to a shop. . .
Better luck w/ the other side.
Old Jan 12, 2002 | 07:39 AM
AznStevie's Avatar
it was easy putting the bushing in. after the bushing is in.... the car handles much better hehe... it's something that you can tell definitely. had it in long time ago. oh yeah..one thing..make sure u oil the bushings, otherwise it'll squeak hehe...
Old Jan 13, 2002 | 02:40 AM
jdmmax's Avatar
DONE finally ride good tighter turning.
well worth the time and money.
Old Jan 13, 2002 | 03:05 AM
KWheelzSB's Avatar
Wooo hooo!
Congratulations!
How long would you say the whole job took from start to finish? Any recommendations for first timers?
Old Jan 14, 2002 | 02:03 AM
jdmmax's Avatar
[QUOTE]Originally posted by KWheelzSB
[B]
Wooo hooo!
Congratulations!
thank you
The whole job took around 8 hrs. and a lot of cussing.
this can be a DIY job but its going to be one of the most frustrating thinks you have ever done. mechanics charge about $100 per side for this job i called a couple of places for prices before i desided to do it myself. those are mechanic's not kids from down the street working at a performance shop. so don't want to hear someone say "well the shop i gotthem from is only charging me $40 to chage both sides." ok go ahead you get what you pay for.
That's it. thanks for the help guys
Old May 2, 2002 | 04:16 PM
jhlee_99's Avatar
well, i've waited six months to get my control arm bushing and there finally here! getthing them installed on monday. the shop is estimating 2hrs @ $68/hr = $136 labor. the bushings were $48. the guy says it's a pain-in-the-a$$ to install these. the stock ones need to be burned/pressed out.
jhlee
[QUOTE]Originally posted by jdmmax
[B]
Wooo hooo!
Congratulations!
thank you
Old May 2, 2002 | 04:49 PM
jdmmax's Avatar
jhlee
yeah maybe i sould have done that good luck !!!!!!!1
Old May 2, 2002 | 09:24 PM
KWheelzSB's Avatar
Say, where did you get your bushings from?
jhlee
Was Energy Suspension out of stock for awhile on the control arm bushings, or was your vendor dropping the ball?
Best of luck w/ the install. Sounds like a very worthy improvement to make.
The front anti-sway bar bushings seem like a very easy DIY job, but based on what I've read here, I think I'll leave the control arm bushings to the pros when the time comes - not sure they're worth the aggravation of DIY.
I've got a new rubberized squeaking noise (not strut, strut mount, or spring related) -started about a month after I did my suspension install.
Anyone have a control arm bushing actually fail b4 replacing w/ the Energy Suspension bushings? Is "squeaking" a symptom of the OEM bushing's failure? Thanks in advance!
Old May 2, 2002 | 10:22 PM
delio's Avatar
anyone have a part number for the sway bar bushings also?
Old May 2, 2002 | 10:35 PM
KWheelzSB's Avatar
http://www.suspension.com/nissancars.htm
Interesting: it appears that Energy Suspension only makes replacement bushings for the frame-mounts on the front anti-sway bar, and not the anti-sway bar end link bushings. Kinda odd.
Old May 3, 2002 | 11:06 AM
jhlee_99's Avatar
you can order the endlinks from courtesy nissan. it's $2.73 each...u need 4.
jhlee
Old May 3, 2002 | 11:08 AM
jhlee_99's Avatar
part number is 7-5118G (front). order from courtesy nissan.
jhlee
Old May 3, 2002 | 02:52 PM
SuDZ's Avatar
jhlee
Due to a fire you will be waiting a while. Thats why mine are backordered now.
SuDZ
Old May 3, 2002 | 02:57 PM
xHypex's Avatar
Here's a link to the parts
http://www.courtesyparts.com/energys...on/maxima.html
-hype
Old May 6, 2002 | 05:25 PM
jhlee_99's Avatar
well, just got my car back. the bushings are installed and I can definitely feel the difference. the feels a lot more crisp for sure. however, the shop ended up charging 3hrs labor instead of 2hrs. he said it actually took him 4 hrs to install these. so my total out of pocket cost was $68/hr x 3 hrs = $204 labor plus $30 for the bushings or $238. so, for the amount of money, i'm not too sure if this was worth it.
i'll get a better idea if this was a good mod for the money once i drive the car around more. for now, i say since you can't really install these easily, skip this mod! my cost/benefit analysis says bad mod for your hard earned $$$ if you have to have a shop install it. if you are able to install them yourself, definitely worth it for $30!!
jhlee
pears
Sep 18, 2015 05:25 AM
Violator
Sep 9, 2015 10:14 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
