4th gen ES adjustable end links
Old 09-26-2012, 11:15 AM
ShocknAwe's Avatar
ES makes some nice adjustable end links and mine need replacing anyways so I am going to get these also to get the SB back in the right position after lowering http://performanceparts.com/part/Ene...ension/9.8169R. They make several sizes and I am not sure the size of the OEM links. Does anybody have a set laying around? If not Ill have to just go to the auto store with a tape measure lol.
ShocknAwe is offline
Old 09-26-2012, 11:31 AM
ShocknAwe's Avatar
The Moog end links are 3.81" so the size I linked would be the correct size to get. I called the local O'reilly and they sell the Moogs for $30/ea(dont link any cheaper, not the point) so for $75 the ES are a little over twice the price. Courtesy sells OEM links for $40 I believe so again about twice the price. WHo wants these? Down for a group buy hopefully?
Old 09-26-2012, 11:35 AM
ShocknAwe's Avatar
Now in order for these to work, it would of course require some modifications to the sway bar IE adding in a U-joint or something similar but that wouldn't cost much and any competent exhaust shop could do the work on the car without removing the entire sway bar itself.
Old 09-26-2012, 01:26 PM
benjie's Avatar
If only your bushings are shot, you could always remove the bushings and buy the poly bushings alone. They sell them as an 8 pack with washers. That's what I wound up doing. Again that is if the end links them self aren't damaged and you can take them apart and put them back together. The other option is buy a cheap set of end links from fcp import and swap out the rubber bushings for the poly. You might need a second hand to press to get the nuts back on though.
benjie is offline
Old 09-26-2012, 01:50 PM
ShocknAwe's Avatar
huh? I dont think you quite understand what I am talking about
Old 09-26-2012, 02:02 PM
benjie's Avatar
I guess I don't understand. What would be the purpose?
benjie is offline
Matt93SE
05-24-2019 02:58 PM
Finkle
09-27-2015 09:53 PM
homeyclaus
09-03-2015 06:15 PM
MaximaDrvr
08-19-2015 08:20 PM
ViciousVQ30
08-05-2015 05:40 PM
Quick Reply: 4th gen ES adjustable end links
