Ypipe concerns
Ypipe concerns
I will be installing my WS Ypipe soon, I have looked at a lot of guides, it seems very basic, I was just curious. Besides rusted bolts, what could go wrong? Do you have to do anything special with gaskets? Also would you recommend wrapping it? I have heard mixed thoughts on wrapping.
If your car stayed up here it's whole life, you're probably not going to be dealing with a ton of ruset and what-not. Might be a good idea to put new gaskets on it though where it meets the main cat.
wrapping...?
wrapping...?
I'd be wary of using a wrap low in the car on a y-pipe like that though. They are known to trap moisture and contribute to rust.
As far as getting rid of the rasp, I doubt wrapping would have any affect. Make sure your exhaust system includes both a good quality resonator and muffler. I had a WS Y, a Magnaflow Cat and a "Stillen" mandrel bent cat-back with muffler (no resonator) and I had some nice rasp. Added a round 4" x 24" Magnaflow after the cat and it got rid of the rasp.
I just came back from the dealer and put gaskets and all new hardware on order, for when my new separately ordered aftermarket y-pipe and cat come in. I figure I'd rather just have spares on hand for when my mechanic does the install.
For 17+ years these parts have been on there, I'm sure a lot of it is all seized up.
If the studs do come out, do they usually just spin out when you try to get the nut off, or do they damage the header on the way out?
I had to grind and drill out all 4 melted bolts on the OEM CAT flanges. I tossed the catback so didn't have to deal with those rusted parts.
To keep the new exhaust nuts & bolts from seizing I loosened them all 2 weeks ago and applied compound again.
I just did mine... PB Plaster is your best friend... soak the bolts and let them sit for about 10 15 min... use a long braker bar to you can add more tension I had my car up on the ramps and everything was ok dont take the bolts all the way out unless you want to drop the pipe on your head lol... brake lose the 02 sensors first and just take your time... always use new gaskets...
Mar 12, 2020 12:06 AM
vingodine
45
May 21, 2016 12:46 PM
lrb6805
Sep 17, 2015 04:49 PM
