hose between the two valve covers?
Old Oct 3, 2012 | 07:08 PM
d0773d's Avatar
Hello all,
What is this hard black plastic hose connected between the two valve covers called? I went to autozone, but they did not have a rubber hose to fit the same diameter. I am S.O.L until I get this hose or something that meets the same measurement so I can finish the valve cover gasket installation.
Old Oct 3, 2012 | 07:17 PM
asand1's Avatar
I installed a clear vinyl hose that fit tightly enough.
Old Oct 3, 2012 | 07:35 PM
d0773d's Avatar
Alright, sounds like a plan. What is the purpose of this hose, anyways?
Old Oct 3, 2012 | 08:00 PM
MaximaSE20's Avatar
I believe it's part of the PCV system
Old Oct 3, 2012 | 08:54 PM
asand1's Avatar
Breather hose to evacuate vapors from the front valve cover.
Old Oct 3, 2012 | 09:02 PM
asand1's Avatar
Old Oct 3, 2012 | 09:10 PM
d0773d's Avatar
Thanks for the picture. Do you remember what diameter your vinyl hose is?
Old Oct 3, 2012 | 09:21 PM
CMax03's Avatar
That's a dealer item....... use can use regular hose for the meantime....
Old Oct 3, 2012 | 09:32 PM
asand1's Avatar
I don't remember the diameter, but it was off the shelf of my local Ace Hardware store. I liked the idea of clear tubing as it "literally" provides a window into the condition of my engine in terms of blow-by and carbon build up.
Personally I would not pay dealer prices for such a simple stretch of hose, and I dont like the high spot in the middle of the OE piece as it might cause vapors to gather and build up deposits. I also removed the associated bracket to un-clutter the top of the engine.
Photo was created Sunday, August 22, 2010, 6:36:00 PM. Don't know when I actually installed it, but it hasn't hardened, yellowed or melted yet.
Old Oct 3, 2012 | 09:53 PM
FallenOne's Avatar
I found a hose for it no problem, stop shopping at AutoZone. I wanna say I used a 3/4" and just ran the hose clamps down real tight with my impact. works fine.
Old Oct 4, 2012 | 05:57 AM
GGENIUS's Avatar
im sure you know what youre doin im just sayin, an impact on a hose clamp is a good way to brake your clamp.
Old Oct 4, 2012 | 06:10 AM
jholley's Avatar
Hello all,
You don't need an OEM part for that breather hose. My local autozone had the correct diameter hose. I installled it 32,000 miles ago and it has held fine with no leaking.
Old Oct 4, 2012 | 06:46 AM
chongher's Avatar
I just used a 5/8 vacumm hose cut to spec from the auto parts store. Fit pretty good.
Old Oct 4, 2012 | 08:05 AM
CallMeThatOneGuy's Avatar
My stock hose was shattered on both ends. I grabbed another one from my garage and popped it on.... no problems with fitting.
Old Oct 4, 2012 | 08:19 AM
Shift_A32B's Avatar
I used a regular hose from O'reilly. I took the old hose to measure the diameter.
Miket2006
Mar 1, 2021 03:55 AM
TKHanson
Nov 24, 2018 01:39 AM
jonreidhead
Jan 6, 2016 09:38 AM
tseng1023
Oct 15, 2015 08:30 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
