Unorthodox UDP help
Old Oct 21, 2012 | 04:33 PM
kasso28's Avatar
Unorthodox UDP help
So, I bought a used Unorthodox Racing underdrive pulley. Looks like they used a pry bar to pull it off the crank instead of using a proper puller. As a result, the timing ring is slightly bent in some places. I removed it and tried straightening out as best I could.
Does anyone know where I can purchase a replacement ring? Or has anyone ran a udp with a slightly bent timing ring with no issues?
Old Oct 21, 2012 | 07:58 PM
nismology's Avatar
Moved.
Old Oct 21, 2012 | 09:24 PM
CMax03's Avatar
I think it time to go to ASP racing and have them make 2 4th gen crank pulleys....a OEM size billet aluminum pulley and an underdriven pulley.....I was busy in the several projects I have/had on my plate....The 4th gen MES catback, The Cattman 3" Hybrid Resonator section for the 5th Gens, and several cars I've been working on locally...I'll start by mailing the one I have to ASP and we'll be rocking real soon!
Old Oct 21, 2012 | 09:30 PM
ShocknAwe's Avatar
^oh really....keep me posted
Old Oct 21, 2012 | 09:47 PM
kasso28's Avatar
ya as long as the price is right...but still doesnt answer my question lol
Old Oct 22, 2012 | 12:32 PM
CMax03's Avatar
It's your call you never posted a pic! So we don't know the severity thru text.....
Old Oct 23, 2012 | 07:41 PM
RA030726's Avatar
I'm nutty for Nissans
If the teeth are still there and the ring does not rub on anything once installed, you should be OK.
UR sells the ring separately. IIRC its $90, which is way too much.
Old Oct 23, 2012 | 10:15 PM
kasso28's Avatar
ya all the teeth are there and I carefully straightened it out on a flat surface. Nothing rubs and the actual pulley part is still fine with no noticeable runout.
I was just a bit paranoid, cause I remember reading a post on someone using an OBX pulley with a slightly bent ring and the car ran like ****...
BkGreen97
Apr 2, 2016 05:47 AM
y2kse
Feb 25, 2001 08:47 PM
GregP
Jan 16, 2001 01:58 PM
vtec killer
Nov 18, 2000 05:53 PM
