is it possible for the timing chain to jump?
Old Oct 29, 2012 | 04:07 PM
99_a32's Avatar
i have a 99 maxima es (its my daily). i went to drive it today and it wants to start but it just wont. first thing that came to my mind was a timing belt but i searched and found out it uses a timing chain instead. it almost starts but it just wont!!! i would turn it over to check for spark and whatnot but i dont want to bend the valves if it is the timing chain.
Old Oct 29, 2012 | 04:11 PM
Shift_A32B's Avatar
Could also be a faulty fuel pump. Dead Crank/Camshaft Position sensors.
Old Oct 29, 2012 | 04:13 PM
chrome91's Avatar
as said, see if youre getting fuel. and as said, could be a crank or cam sensor
all the times ive see a timing chain jump from the tensioner frigging up or whatnot, the car runs like crap. like it'll barely hold idle and sputter and spit, not just plain not start. its also rare that a chain breaks
check it for spark first, if you have spark, hook up a fuel pressure gauge and see what youre getting
Old Oct 29, 2012 | 04:18 PM
99_a32's Avatar
fuel pump turns on, could it still be faulty? where would i find the cam/crankshaft sensors?
Old Oct 29, 2012 | 04:30 PM
Shift_A32B's Avatar
http://www.nissanpartsasap.com/nissa...ointVehid=9591
That's the illustration for the Cam/Crank Position sensors.
Camshaft Position Sensor sits on the top. [23731M]
There's 2 crank position sensors, which sit on the bottom. [23731T & 23731TA]
Any CEL by any chance?
Old Oct 29, 2012 | 04:46 PM
99_a32's Avatar
the check engine light has been on since i got it, was going to get it checked out but i kept procrastinating and now it doesnt run haha. going to see if i can borrow the code reader so i can scan it.
Old Oct 29, 2012 | 04:52 PM
Shift_A32B's Avatar
Best bet is to get the codes.
Old Oct 29, 2012 | 05:18 PM
chrome91's Avatar
fuel pump could still be giving pressure, but not enough
best to get the codes read first though, that'll probably tell you whats up
Old Oct 29, 2012 | 05:24 PM
2brosgixxer's Avatar
You can check the codes yourself with no scanner needed. See my sig for the link to the 4th gen section..in there, there is a section for what to do if cel is on. There is a step by step there on how to get your codes by turning the screw on the ecu. Edit...here is the direct link http://forums.maxima.org/4th-generat...ere-first.html
Old Oct 29, 2012 | 08:13 PM
JNCoRacer's Avatar
Just the tip.
He said its a 99. Possible NATS issue?
Old Oct 30, 2012 | 07:57 AM
Trini Boom's Avatar
Negligence on your part sir... was the light flashing at any point in time?
Old Oct 30, 2012 | 11:49 AM
asand1's Avatar
This. Is the security light staying lit solid?
Old Oct 30, 2012 | 12:02 PM
Amerikaner83's Avatar
FIRST and FOREMOST, when you're cranking the car, is the little red SECURITY light ON?
Old Oct 30, 2012 | 12:46 PM
Shift_A32B's Avatar
forgot to mention NATS. Well I don't know anything about that.
Old Oct 30, 2012 | 10:55 PM
99_a32's Avatar
that was the first thing i checked im not sure if this is a load of **** or not but apparently in order to use the code reader the engine has to be warm. im 99.99% sure this is false, can anyone verify?
Old Oct 30, 2012 | 10:56 PM
99_a32's Avatar
well to be specific, it was the service engine soon light which im pretty sure is the same thing, and it just stayed on, never flashed
Old Oct 30, 2012 | 11:13 PM
tosheto's Avatar
Your engine does not need to be warn at all. Go to autozone or check the codes yourself the way it was posted above. Why would you want to start fixing things and/or buying parts without even checking the codes on your ECU
Old Oct 31, 2012 | 06:16 AM
Crusher103's Avatar
highly doubt the timing chain would jump, it is a possibility but extremely rare.
Old Nov 1, 2012 | 11:13 AM
99_a32's Avatar
ok, so i go the codes 9 long pauses 2 short, 3 long 4 short, 3 long 2 short. knock sensor, EGR System Hi/Low Flow and a rear heater o2 sensor.
Old Nov 1, 2012 | 12:03 PM
99_a32's Avatar
sorry about the double post. would any of these problems cause the car not to start.
Old Nov 1, 2012 | 02:31 PM
asand1's Avatar
Knock sensor and REAR o2 would not affect starting. High EGR flow might.
EGR (Exhause Gas Recirculation) passes exhaust gasses back into the intake manifold at cruising speeds to lower combustion temps. Engines dont idle or pull good on inert gasses.
Low flow would not affect starting either.
Old Nov 1, 2012 | 02:34 PM
asand1's Avatar
you need to search "no start" and study. Most common causes are NATS, IGN switch, and poor grounding. crank and cam sensors are common too.
Old Nov 1, 2012 | 02:55 PM
99_a32's Avatar
ive already ruled out nats, and the ign switch. wouldnt the crank and cam sensors throw a code? my maxima has 314xxx km
Old Nov 1, 2012 | 04:56 PM
asand1's Avatar
How have you ruled them out?
Old Nov 1, 2012 | 05:39 PM
Shift_A32B's Avatar
Yes, ECU would throw those codes.
Old Nov 1, 2012 | 10:20 PM
99_a32's Avatar
my security light stays off when the key is turned on, and ive had the ignition switch problem for awhile now, if it was the ignition switch the car wouldnt turn over.
Old Nov 1, 2012 | 10:45 PM
asand1's Avatar
Bad ignition switches do cause a no start condition exactly like this. Myself and others have experienced it.
http://forums.maxima.org/4th-generat...ape-trick.html
http://forums.maxima.org/4th-generat...lock-woes.html
Sometimes it can be solved with some tape, other times it is the result of burned contacts in the switch. Remove the switch and try to start it with a screwdriver.
Old Nov 2, 2012 | 10:10 AM
99_a32's Avatar
so did your car turn over and almost start but just wouldnt go that extra little bit?
Old Nov 2, 2012 | 12:54 PM
99_a32's Avatar
so i tryed to start it today and when it almost started i stepped on the gas and it runs!!! it puffed alot of white and smelled really rich. now it starts every time and doesnt puff white anymore.
* any idea what it could have been?
Old Nov 2, 2012 | 02:50 PM
maxinout93's Avatar
I just solved my weird starting problem, sumtimes it would start and other times i would turn the key and get a scraping noise like the car is already started. I changed starters, and ignition switches, and fuses and relays but still got the same noise at every other startup. I finially changed the crankposition sensor near the transmission, the old one had so much metal shavings on it, so i swapped it out, and the car has started right up ever since, no more scraping noise! Wow!
mvm062
Nov 30, 2020 09:00 AM
maxinout93
Oct 27, 2015 01:29 PM
kjlouis
Oct 3, 2015 05:29 AM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
