Joining the 3.5 swap club
Came across this, maybe you've not seen it yet? 22 bucks for the corner light...
Video Link: http://www.amazon.com/dp/B002R13Q3S/ref=cm_sw_r_an_am_ap_am_us?ie=UTF8
They were terrible.
I don't even think they gave me TYC as advertised.
I told them if they found me a perfect pair I would take them.
Thanks though.
And they were $16 last week..
Need some help here.
I have a clutchmasters stage 2 clutch that my mechanic blames for all my problems.
It will not go into gear after swapping out my OEM.
Tried a new slave, the master is new, and it has been bled properly.
He says the throw out bearing is too short.
Shouldn't it work fine with the clutchmasters bearing?
Edit: Fixed. Just needed a different mechanic to look at it. The previous mechanic did not know how to adjust the clutch pedal properly.
Should be picking it up tomorrow morning.
Updated my to do list.
Almost all of it done.
Had my first drive in a long time today.
I missed my Maxima; sucks it had to be a drive to Wal-Mart.
I need to road trip and break this clutch in..
So.....to be installed in no particular order:
Rear main seal for transmission-DONE
Passenger whole axle-DONE
Driverside whole axle~Autozone Gold new-DONE
Clutchmaster stage 2 kit-DONE
Ralco RZ flywheel-DONE
plugs
Pressed polys into lca's-DONE
All FSB polys-DONE
Progress RSB-DONE
Subframe bushings kit-DONE
Grounding kit
All led's~pending arrival
Fogs/brackets/switch-DONE
Oil catch can~seller backed out :/
Otto FSB to clear the new:
NWP spacers
Retroing headlights soon too.-Everything has been sent to Chris~pending arrival
plugs
All FSB polys-DONE
Progress RSB-DONE
Grounding kit
NWP spacers
http://www.theretrofitsource.com/pro...roducts_id=227
The corner lights the guy was selling were really old as well.
I don't think I would be happy with more 15 year old corners. Thank you though.
The search continues.
Retros are shipping on Monday.
Thanks to retrofits-r-us:
http://www.retrofitsrus.webs.com/
Edit: I have tracking!!!!
Should be here by Friday and I should have my car back today or tomorrow.
Edit,Edit:
Retros are here and purdy, but still no car as of 3/20:waiting for parts.
Edit,Edit:
I finally have it back AND functioning correctly.
I'm installing the retrofit headlights tomorrow, as well as a few other interior pieces.
I might have a go at drilling out my old ignition and putting in the new one I've had forever.
Tomorrow will be a busy day for my Maxima in the driveway, but I'm going WOT as soon as I'm too anxious...maybe I'll get that out of the way tonight.
Tomorrow will be a busy day for my Maxima in the driveway, but I'm going Back Seat Fapping as soon as I'm too anxious...maybe I'll get that out of the way tonight.
Sent from T_Bittys Melon Farm
http://www.klearz.com/nissan.html
This guy also makes the front smooth clear corners for the headlights
I am going to do everything in my power to get my clutch working today.
New OEM slave and push rod to be installed, then the dreaded pedal adjustment.
I. Want. My. Fast. Expensive. Maxima. Back. Now.
I think I'll give her mine and get that all aluminum one I've seen on here. Sounds like a good excuse.
UPDATE. Master was leaking in cab/so that's bad, slave has been replaced.
Now waiting on a rockauto master.
I'm going to get this done danm it.
I've swapped the rad 3x~I can do that blindfolded.
I finally figured out how to adjust the clutch pedal; by having the master out I can see that I loosen the nut and use pliers or vice grips to rotate the rod going to the master until it reaches the nut to stop it.
That whole thing had me confused as he!!
It took me taking it out to understand it.
Boy do I feel dumb.
I'm very happy to be doing this myself though.
Should have all along.
I just get easily overwhelmed.
My determination is winning this time.
It helps that shops are always lying to me and screwing me over. That's motivation enough.
true. I'm overwhelmed by most mechanical things, myself. Hell, I don't even change my own oil for fear I'll **** something up
And btw you can just type in hell...the filter doesn't do that one
18" g35s with all weather somethings...lol
Usually I would know the tire brand right off, but these came with the wheels.
I heard the rear rub on a bump.
Roll and pull time.
I might have to put the 2k2 wheels on, but these G35s are so damn sexy.
Roll and pull time.
