Dose anyone know where this goes
Old Nov 3, 2012 | 04:32 PM
###'s Avatar
My today my radiator was leaking (time of a new radiator) . So to find the leak I took the factory cold air intake off and I found this plug resting near the transmission. I think it might have something to do with the transmission .
sorry Phone pics
Old Nov 3, 2012 | 04:45 PM
ShocknAwe's Avatar
any odd shift behavior recently? what color is that connector? Could be for the revolution sensor
Old Nov 3, 2012 | 04:50 PM
GGENIUS's Avatar
doesnt look like it goes very far.
Old Nov 3, 2012 | 05:14 PM
DennisMik's Avatar
I have that connector hanging loose also. I don't know what it is for, but the car runs fine. I zip tied it to the harness so it doesn't flap around. If you look at the op's photos, based on the dirt on it, that connector has not been connected for a long time.
Old Nov 3, 2012 | 05:38 PM
ShocknAwe's Avatar
hmmmm I will have to investigate this. Possibly I removed mine.
Old Nov 3, 2012 | 08:17 PM
cjanderson3's Avatar
I can't quite tell where your at, but could it be the electronic front motor mount plug? Not all cars have it and these maxima's have a reputation of having wiring included in the harness that's not necessarily used on that particular vehicle
Old Nov 3, 2012 | 08:30 PM
tmorales509's Avatar
On the 3rd gen there is a plug like this hanging not connected to anything. I think its normal but not 100% sure.
Old Nov 3, 2012 | 10:41 PM
Venix's Avatar
Thats suppose to be plugged into the antenna motor
Old Nov 3, 2012 | 10:48 PM
surban1's Avatar
if the op has a 99 gle (as his sig identifies), then he should have the electronic front motor mount, so it shouldn't be that. with the location he specifies, my guess is abs actuator; does the op have abs brakes or not?
Old Nov 4, 2012 | 12:27 AM
###'s Avatar
Wow thanks for all the replies .Yes it is 99 gle the location is under the factory cold air intake a few inches from the battery. The color of the plug is brownish . I think I have abs (abs light when key in Acc) and the car shifts hard when I accelerate faster than normal it will get to 3-4k rpm but its Been like that seance I got It 3 years a go . Also the accelerator peddle has been hard to push when the I am at a light could this be also related to that plug or is it cuz it's getting cold . Thanks for all the help.
Old Nov 4, 2012 | 09:53 AM
DennisMik's Avatar
That plug is not causing the accelerator problem. The accelerator uses a cable between the pedal and the throttle body, strictly mechanical, no electrical things involved. Check the cable that it is not kinked. Disconnect it from the throttle body and see if the pedal is still hard to press. If it is, the cable needs to needs lubricated or replaced.
Old Nov 4, 2012 | 10:24 AM
GGENIUS's Avatar
good one
Old Nov 4, 2012 | 04:29 PM
styliztik's Avatar
it's some sort of option. mine's a 98 gxe and mines taped up all nice and neat
Old Nov 4, 2012 | 06:18 PM
surban1's Avatar
[QUOTE=styliztik;8655961]it's some sort of option. mine's a 98 gxe and mines taped up all nice and neat
do you have abs?
Old Nov 4, 2012 | 06:55 PM
###'s Avatar
@ styliztik thanks for the better pics . I too would like to know if you have abs.
@surban1 I think you maybe right I found this post about electronic mounts http://forums.maxima.org/5th-generat...ounts-ecc.html
Old Nov 4, 2012 | 06:59 PM
Venix's Avatar
Originally Posted by GGENIUS
good one
i only said that to see if Mr GGENIUS was still stalking me... Never fails
Old Nov 4, 2012 | 08:11 PM
styliztik's Avatar
Negative. I do not have abs.
Old Nov 4, 2012 | 08:21 PM
GGENIUS's Avatar
do you really think i could sleep at night without exchanging a few words with my bff?
Old Nov 4, 2012 | 08:47 PM
surban1's Avatar
below, styliztik says has does NOT have abs; your 99 gle (and all 95-99's)only has a front electric motor mount. you can check if you have abs by looking for the actuator doohickey with lots of brake lines going into & out-of it just in front of & below the brake master cylinder. lines from the brake master cylinder will run to it (the actuator) if you have abs; you also may have noticed the brake pedal "pulsate" upon "slamming" the brakes. i'm still going with guess about abs related.
pfactor172
Mar 5, 2004 02:50 PM
custommaximaSE
19
Mar 4, 2004 06:05 AM
raymond3414
Jul 23, 2003 09:54 AM
