broken lug stud replacement?
Old Nov 5, 2012 | 05:46 AM
vgq2's Avatar
Hey guys I have a quick question. I was working on my suspension this weekend a bit and I immediately broke off a lug stud in front while taking my wheel off. To clarify I wanted to make sure of the stud size so I can replace it. To my understanding it is 42mm x 1.25? Also, anyone have advice as to how to remove the remaining chunk of stud from my lug? I do not want to buy a whole other spline drive set. Thanks in advance!
Old Nov 5, 2012 | 03:08 PM
thedwyer00's Avatar
M12-1.25 x 42mm
Knurl Diameter: 14.35mm
Shoulder Length: 13.5mm
http://www.oreillyauto.com/site/c/se...996&vi=1211432
As for a tool to use, try Advance, AutoZone, NAPA, and the like, to rent the tool.
Old Nov 5, 2012 | 04:40 PM
asand1's Avatar
Your stud probably broke because it is cross threaded. You can probably get one nut online.
Old Nov 5, 2012 | 05:09 PM
chrome91's Avatar
lugnuts can just seize on and break with the stud, its happened to me many times. nothing you can do to prevent it really
i havent done one on a 4th gen before, but use a hammer to smack out the remaining piece of the old stud. then, put the new stud through, and put washers on the front of it. put a lugnut infront of the washers, and tighten the lugnut with a airgun. it'll pull the new stud through, once its tight just undo the lugnut and washers and youre set
Old Nov 6, 2012 | 07:16 PM
Remove wheel, remove caliper/rotor, knock out what's left of the stud, put the new one in, reinstall the caliper/rotor, put a couple washers over the new stud and use a lug nut to pull it through then reinstall the wheel.
Old Nov 7, 2012 | 06:32 AM
GGENIUS's Avatar
^^ perfect how to. couldnta said it better myself.
although i havent done one on our cars, but depending on front wheel or rear wheel, some cars require you to remove the hub to replace a stud on the front. fronts can def be a ***** sometimes.
Old Nov 7, 2012 | 08:24 AM
ShocknAwe's Avatar
I was promised a naked picture of you in your avatar chris.....
Old Nov 7, 2012 | 08:54 AM
vgq2's Avatar
Thanks a lot guys. And apparently a guy I work with used to do collision so he has some extractor kits I can use to get the stud leftovers from inside my lugnuts. mmm.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
tnewbs
Aug 28, 2015 10:15 AM
