High Idle, P0505
Old Nov 10, 2012 | 06:33 AM
garends's Avatar
High Idle, P0505
Hi,
Recent bought a 1996 SE 5 speed. My idle is high 1100 rpms (in neutral) and I am getting a P0505 and a knock sensor code. The idle is solid, and not erratic.
I know the previous owner replaced the MAF 5,000 miles ago.
I tried unplugging the TPS and tightening the IAC idle screw down, but 1100 is as low as it will go.
I also tested the IAC with an ohmmeter and it tested good at 30-31 ohm across the pairs. Hope this isn't a fried ECM.
What should my next route be? Is there any way to diagnose a bad ECM?
Thanks in advance. I am really impressed by this Maxima so far (beside this little problem)
Graham
Old Nov 10, 2012 | 07:05 AM
maxima2fst4u's Avatar
if thats all your getting next thing i would check is some vacum hoses have u checked any of those and make sure none are crack or off...if u want to try that and dont see any try some wd-40 or pb blaster and spray around any vacum lines..if there is a leak or crack `it will idle up faster do to the flammable liquids this is what i do on my car and others and works and use this method for leaky intakes
Old Nov 10, 2012 | 07:06 AM
and u can use starter fluid anything flammable and hair spray dont work that good so dont try that
Old Nov 10, 2012 | 02:00 PM
DennisMik's Avatar
Does the IACV look like it has been changed? The P0505 code is for the IACV. If the previous owner had a problem and replaced it, you could be stuck with a bad ECU. Other than than remove the ECU and open it up, I don't know how to test it.
read this thread - http://forums.maxima.org/5th-generat...d-seconds.html
Old Nov 10, 2012 | 02:33 PM
JAmerican's Avatar
I recommend you check this as well since it may be related...
http://forums.maxima.org/4th-generat...placement.html
JAmerican
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
