Transmission replacment
Old Nov 26, 2012 | 10:59 PM
MajorReflexes's Avatar
hi guys my transmission is messed up i have a 95 maxima with an automatic trans im a do it your self-er for the most part. if i were to replace the transmission what kind of tools would i need for the job besides a ratchet set. any how to's or advise would be great couldn't find any online.
Old Nov 26, 2012 | 11:15 PM
thetorp's Avatar
Time and patience. Transmission fluid. There might be a gasket or two. Its not hard of a job its just involved. A FSM would be very helpful too
Old Nov 26, 2012 | 11:28 PM
Quickywd01's Avatar
Most difficult part is putting the trans in because it's a little heavy. I used rope and a 2x4 piece of wood with some help but using an engine hoist to hold it in place would be the easiest way. Download the FSM factory service manual. It tells you what to do and how to do it with what tools to use.
Old Nov 27, 2012 | 06:30 PM
maxed_out_99's Avatar
unbolt the 4 14mm bolts on the torque converter before you remove the trans. never remove the torque converter.
pull the 19mm drain plug then remove all but 2 of the 16 pan bolts leav 2 on each corner of the long side closest to the radiator. this way you will get all of the fluid out of the pan instead of taking a shower.
disconnect the struts and pop out the axles dont remove them.
dont forget the cooler lines going to the radiator.
remove the 4 bolts holding on the mount.
remove the starter and the solenoid connector.
remove the bell housing bolts
then the trans should just come right out
Old Nov 27, 2012 | 06:54 PM
ShocknAwe's Avatar
^ pretty much. If you have a working tranny to drop in then its pretty straight forward, just ensure you put in enough fluid before you go for a drive and I mean double and triple check. Although some say it doesn't help, I know it does via before and after temps, I would go ahead and put in an aux tranny cooler not for performance, but for longevity of the tranny and because the stock cooler within the rad is far from efficient. It is a 30min job and costs all of $70. Other than that, I would consider a valve body upgrade if you like spirited driving. Its a bullet proof tranny despite what some say about it and it can hold over 350hp.
Old Nov 27, 2012 | 08:39 PM
asand1's Avatar
CLEAN THE COOLER AND LINES OUT. Brake cleaner and compressed air work good for this.
Old Nov 28, 2012 | 04:31 AM
thank u appreciate the help
Old Nov 28, 2012 | 04:33 AM
where could i get a upgraded valve body and cooler
Old Nov 28, 2012 | 04:47 AM
never mind found transgo but thanks any way
CorollaULEV
30
Aug 9, 2021 08:11 PM
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
PH98I30
Aug 20, 2015 04:25 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
