Fuse link keeps blowing
Old Nov 28, 2012 | 11:23 AM
sirposted's Avatar
I put in a new alternator new battery and new fuse link, as soon as i put the negative terminal to the batt the fuse link pops i get a new fuse and it happens again if it sits longer than a day the battery dies.
Old Nov 28, 2012 | 11:41 AM
Amerikaner83's Avatar
there's a short...likely in the alternator. Did you have it tested before you put it in the car?
Old Nov 28, 2012 | 11:45 AM
asand1's Avatar
Why did you replace the alternator? Whas it blowing the fuse prior?
Old Nov 28, 2012 | 11:46 AM
[s3]'s Avatar
Alternator installed wrong or replacement alternator bad.
Old Nov 28, 2012 | 12:00 PM
asand1's Avatar
Don't condemn the alternator yet. If the old one did the same thing its something else.
Old Nov 28, 2012 | 12:23 PM
sirposted's Avatar
well i replaced it because the batt wasn't holding a charge even with a good fuse, how could i of put in the alternator wrong its just one connector and that one ground bolt (very easy) and its matches up to my old one perfectly, its a new one not re-built
Old Nov 28, 2012 | 01:19 PM
[s3]'s Avatar
True, but double check to see if there's any metal to metal contact between that "one connector" and anything else.
You definitely have a short somewhere.
Old Nov 28, 2012 | 01:42 PM
sirposted's Avatar
ok ill check it out
Old Nov 28, 2012 | 02:00 PM
sirposted's Avatar
wait metal to metal.....that one bolt actually has two nuts. there was one on there already with a aluminium or ceramic chunk and another bolt on top (so it went nut-chunk-nut) i took off the top nut and put my connector on but the other nut couldn't catch a thread so i took off the chunk since my old one didn't have it. (now its nut-connector-nut) the car fired up fine with a new battery and held a charge for two days then one day dead
Old Nov 28, 2012 | 02:04 PM
[s3]'s Avatar
Well it's kinda like this....there's a + wire going to the alternator, if that wire comes in contact with the housing of the alternator or any other part of the engine your entire engine becomes + charged, once you slap the - terminal on to the battery, voila you've just created a short (fuse pops) ... or at least that's what the system should do.
tarun900
19
Dec 20, 2021 06:57 PM
leatherneck
Sep 30, 2015 09:16 PM
Noela
Sep 26, 2015 08:22 AM
