Please Help! P0340
Old Nov 29, 2012 | 02:07 PM
mr2_fast4u's Avatar
Please Help! P0340
Ok So Its Been 2 Days and My Car wont Start. Its a 98 automatic maxima. It Just cranks but refuses to turn over. The only code thats coming up is p0340 Crank Position Sensor bank 1 circuit malfunction. I changed the Battery, Starter and fuel pump and the problem persist. I checked all the fuses and their good. I tested the coils and their getting power but Im not getting any spark at all upon cranking. I replaced both crankshaft position sensors as well as the camshaft position sensor and no luck. Please Help Any Input will be greatly appreciated Thanks.
Old Nov 29, 2012 | 04:01 PM
ATTappman's Avatar
Holy parts changing! That's the DTC for the camshaft position sensor. After replacing it, did you measure the voltage on the signal wire, to see if it's pulsing like it should when cranking the engine? Then make sure that same pulse is present at the ECM. Without a scope or a digital voltmeter with graphing capability, it will be hard to see exactly what's happening but you should see the signal voltage jumping between +9 and -9 V, relative to battery negative.
Old Nov 29, 2012 | 04:54 PM
89newporker's Avatar
Double check the ground of this circuit, will be the black wire leading directly to the intake manifold. the white wire is from terminals 46&47 of the ecu that is where you should receive an approx signal of 4.5 volts.
Old Nov 29, 2012 | 09:30 PM
mr2_fast4u's Avatar
Ok Thanks Will let u know what happens
Old Nov 29, 2012 | 09:32 PM
mr2_fast4u's Avatar
Ok will try it as soon as i get a chance
Old Dec 1, 2012 | 05:17 AM
Trini Boom's Avatar
Inspect the wire harness going to the sensor.
Old Dec 1, 2012 | 07:04 AM
Markusfisher's Avatar
Perhaps it's a possibility that your timing chain has stretched or your tensioner is failing
Old Dec 1, 2012 | 06:53 PM
Trini Boom's Avatar
Timing chain stretched??
Old Dec 2, 2012 | 07:11 AM
Dark_man_x's Avatar
The tensioners failing could be a possibility once all electrical has been proven to be in good working condition. We all know these cars are notorious for harness issues.
Old Dec 2, 2012 | 10:24 AM
Mr. Brett's Avatar
What did I click on...?
Old Dec 3, 2012 | 06:43 PM
kelly747's Avatar
there is a 10amp fuse thats up the hood in the driver side fuse box check an see if that fuse is blown ( on the fuse box cover it should say e.c something test the fuses an see if any is blown
martinamw
Sep 8, 2015 12:12 AM
wingnut2006
Aug 15, 2015 04:16 PM
Jersey Woods
Aug 2, 2015 06:19 PM
dcardello
Aug 2, 2015 10:16 AM
