fixing my flooded 98
Old Dec 14, 2012 | 03:05 PM
gldmaxx98's Avatar
well im having a fuel problem im not getting power to my fuel pump theres 2 plugs one has two wires no power the other has four wires only one wire is getting power i changed the three computers under the radio alt and starter the car started once then i put new oil new gas now wont start i tested the fuel pump works fine just not getting eough power maybe theres more relays and computer i dont know about any help will be
Old Dec 14, 2012 | 03:06 PM
Quickywd01's Avatar
Should've changed the fluids before starting it.
Old Dec 14, 2012 | 03:10 PM
gldmaxx98's Avatar
everything is good just not getting enough power to the pump
Old Dec 14, 2012 | 06:04 PM
DennisMik's Avatar
There is a fuel pump relay. It is located behind the kick panel on the driver's side. If the car has a sun roof, that relay sits next to the fuel pump relay.
Pin 11 of the ECU grounds out the energizing coil of the fuel pimp relay. The relay contacts close and power from fuse # 32 (15 amp) goes to the fuel pump.
Old Dec 14, 2012 | 07:21 PM
eddie982's Avatar
Good luck bro.
I bought a replacement 98 auto ECU for my max but the car was junked, still have the ECU, if anyone wants, pm me.
gigabyte
Jan 6, 2017 06:05 PM
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
