Rpm Needle moving when cranking but no start
Old Jan 7, 2013 | 07:39 PM
TravisCadello's Avatar
99 max auto...jus installed new I.M gaskets and Transmission been down for a week. Didnt have much daylight tonight but enough to see all my sensors are connected. but motor turns over n over not even trying to start. no fuel. the Rpm gauge goes in between 300 n 600 rpm when cranking ive never seen this...any advice?
Old Jan 7, 2013 | 07:54 PM
Trini Boom's Avatar
I am going to go out of my way here and check the CKPS sensors... Scan for codes..
Old Jan 8, 2013 | 05:59 AM
No codes. battery been off over a week. i tried. why does our rpm gauge get the reading from? coil packs correct?
Old Jan 8, 2013 | 08:23 AM
Max139617's Avatar
Well dude if you have a 99 check the immobilizer. The light should be sold while youre trying to start her up
If that doesnt work and you say you dropped the tranny you may need to sand the mating surfaces and add a ground from the 17mm starter bolt to the negative battery terminal.
Old Jan 8, 2013 | 08:32 AM
Max139617's Avatar
But I'm pretty sure you have a grounding issue. Check what I mentioned on my post above
Old Jan 8, 2013 | 02:45 PM
2brosgixxer's Avatar
Did you clean the mating surface on the tranny and motor when you replaced your tranny? Adding grounds will not fix the problem if you didn't clean the mating surfaces. I dealt with the same issue.
Old Jan 8, 2013 | 02:58 PM
Amerikaner83's Avatar
THIS
THIS
...AND THIS
Old Jan 8, 2013 | 05:30 PM
Max139617's Avatar
Travis I know you're not new here but this could've all been searched up.
Try fixing it simply first with just the grounding wire, and if that doesn't work then attempt the mating surfaces. I guarantee that your problem will be fixed if you do these 2 things.
Old Jan 8, 2013 | 06:21 PM
I searched alot noone has symptoms like mine...im getting LOUD BACKFIRES.FIRES OUT MUFFLER GUN SHOT SOUNDS,sounds like timing is completly off. rpms gauge goin to 1500rpm when cranking...codes are p1490 and p0446...had a crank sesnor code now its gone put new crank sensor under pulley.
Old Jan 8, 2013 | 06:26 PM
i had two set of short jumper cables ran from NEG Battery,one ground to starter bolt,one to alternator ground and other to ground on lower intake manifold with two ground cables comming out harness..No go.
Old Jan 8, 2013 | 06:32 PM
I Remove the Crank sensor under Harmonic Balancer and the engine cranks over completely normal and RPM gauge sits at 0, I Connect it and it back fires BADLY from Exhaust only and Grayish white smoke comes out muffler.
This is the work i performed.
1-Complete New Injector Rail n all injectors out junk yard.
2-New Auto Transmission.
3-removed flex plate to inspect rear main seal.
4-installed new Electrical clip for Ignition Coil In Front.
only thing i can think of at this point is that i Fried the ECU Because when the coil clip shattered when i removed it i still slid the wires on the coil and started it and maybe the power transferred from one the electrical terminals to the other and shorted something out.
Old Jan 8, 2013 | 06:39 PM
Max139617's Avatar
Well dude ive seen an exact thread describing the same symptoms and they even posted a video. But i was deep lurking yesterday when I found it.
Is it like that ? If it is the guy who posted the video, got it to work after he added the grounds.
Before you start changing sensors like me and amerikaner have suggested: SAND THE MATING SURFACED . good luck OP
Old Jan 8, 2013 | 06:45 PM
http://www.youtube.com/watch?feature...&v=GyDcMjiWaHs
Sorry but im not removing my entire transmission again just to sand it,If theirs no way around it i guess ill have to lol, But yes Thanks Alot Bro that Video is EXACTLY what mine is doing and this is my 4th Tranny in this car n i NEVER heard or had to sand the mating surfaces Thats weird lol.
When i added three grounds straight from NEg battery to ground with jumper cable why didn't it start if it was grounds?
Old Jan 8, 2013 | 06:52 PM
I ran 6 4GA wires as grounds after my clutch was replaced and that was not enough. Per the Nissan dealer, the mating surfaces on these cars are a MAJOR grounding point. The ONLY way to fix this is to pull the tranny and clean those surfaces. Stop banging your head and wasting time on trying anything else until you pull the tranny again and clean it. DO NOT SAND it, just clean it up real well with a wire brush. If you don't want to pull the tranny again, you will not fix your problem.
Heres my thread with video in post #8 http://forums.maxima.org/4th-generat...hen-start.html
After i pulled the tranny and cleaned those surfaces, It fired right up.
Old Jan 8, 2013 | 07:05 PM
Max139617's Avatar
Yeah dude, the mating surfaces are one of the biggest grounds. Just adding the ground cables will not be enough. I just suggested doing that first because its a lot simpler and a lot cheaper.
LOTS of people have gotten to start this way. Tavarish being one of them. hold up let me find the videos.
This is before he sanded the surfaces. Granted its not as bad as the previous video and he did manage a start if you read the first comment he will say how he fixed it.
Since you have added grounds, changed the ckps sensor this is THE ONLY THING left for you to do. Youre gonna have to pull the tranny if you want her to start again
And then here is the after video. That baby fires right up
Old Jan 8, 2013 | 07:08 PM
Make up your goddamned mind, Travis! Codes or no codes? Geez every thread you start ends up like
Do as you've been told MANY TIMES already. Remove your trans and scour the mating surface to the engine!
Wow, Thats crazy! I Wonder if i could just loosen the tranny and get it a little away from block and run a scortch pad in between the mating surfaces and then spray some carb cleaner and torque tranny down if that should work?
Old Jan 8, 2013 | 07:15 PM
^^^ You will need to get every square inch. Make sure you do both sides (Engine and Tranny). Personally I would just take the whole thing out again and do it right and call it a lesson learned. It sure would suck to only take it partway out, clean it some (half assed), then find out that didn't work then have to go thru the process AGAIN.
Old Jan 8, 2013 | 07:17 PM
This is exactly what is going to do.
Old Jan 8, 2013 | 07:27 PM
well it wont take me but 15 minutes to back all the Tranny bolts out halfway with Impact Versus 4 Hours to completely remove it and clean it and put back (yes i can uninstall then install a A/T in 4 Hours Done 4 on this car and 2 on 95)
And im pretty possitive i can get the scotch pad all the way in and it will clean both the block and tranny same time and i've seen the gap i can get out of it and its enough...if it still dont start ill go ahead and take it all out again..
HEY, THANKS ORG!!!
Old Jan 8, 2013 | 07:31 PM
told ya.
Old Jan 8, 2013 | 07:38 PM
Max139617's Avatar
Thank us when you get that bish started lol.
hmm give back to the org by recording/taking pictures of the process? or am I asking for too much ?
Old Jan 8, 2013 | 08:11 PM
Old Jan 8, 2013 | 08:34 PM
Sure will.
Old Jan 11, 2013 | 12:05 PM
I painted my entire tranny so alls i did was remove tranny bolts one by one n sand all paint off around where the washer contacts the tranny and she started right up! Thanks Org!
Old Jan 11, 2013 | 04:58 PM
Trini Boom's Avatar
Why was this not mentioned in the original post??
Old Jan 11, 2013 | 06:26 PM
Max139617's Avatar
-.- not like this was important or anything.
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
dcardello
Sep 3, 2015 11:44 PM
