Trouble Removing Right Fender Bolts
Old Jan 8, 2013 | 06:13 PM
lskiat's Avatar
Hello everyone,
I recently got a '98 Maxima which has a rust hole on her right fender. I decided to try removing the rust and patching it up myself. To do that, I plan to remove the entire fender so I could work on the rust beneath the paint. However, I ran into some difficulty trying to remove some bolts.
First off, here is a diagram that shows the location of that bolt. It is highlighted by the red box.
(taken from http://www.courtesyparts.com/maxima-...1897_1901.html):
And here are some real-life photos of one of that bolt (left fender because the right ones are a little messy right now):
I also managed to get a photo of the underside of that bolt:
I've tried phillips screwdrivers, spanners (no size would fit), even pliers but the bolts just won't budge. I've sprayed some WD-40 on them and am hoping they would be loose by tomorrow. Has anyone encountered a similar problem? I would appreciate some advice on this matter.
Thank you!
Attached Thumbnails Trouble Removing Right Fender Bolts-diagram-bolt.jpg   Trouble Removing Right Fender Bolts-bolt1.jpg   Trouble Removing Right Fender Bolts-bolt2.jpg   Trouble Removing Right Fender Bolts-bolt3.jpg   Trouble Removing Right Fender Bolts-underside.jpg
Old Jan 8, 2013 | 06:21 PM
Trini Boom's Avatar
That's a 10mm socket. YOu should spray top and bottom to loosen up. Had one of mine break off but not much you can do besides that.
Old Jan 8, 2013 | 06:45 PM
lskiat's Avatar
Thanks for the advice!
Old Jan 8, 2013 | 08:08 PM
tosheto's Avatar
Soak it with PB blaster and then use 10mm socket and a ratchet. It should come off. Unless it is way rusty. Then it might brake
Old Jan 9, 2013 | 07:57 AM
[s3]'s Avatar
You don't have a socket set? It's not even rusted.....get some basic tools before you go further.
Old Jan 10, 2013 | 12:03 PM
Logan30's Avatar
+1 Just make sure you get a metric ratchet set.
Old Jan 10, 2013 | 07:59 PM
cjanderson3's Avatar
He said he took a picture of the other side, so the one he's trying to get off could still be rusted.
I had the same problem with the rust and when I took the fender off I snapped one in the door jam.
PB Blaster or I've heard good things about Seafoam Deep Creep
Noela
Sep 26, 2015 08:22 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
bumpypickle
Sep 19, 2015 01:07 AM
Colossus
Sep 9, 2015 05:46 AM
