P0500 and P0600
Old Jan 17, 2013 | 01:48 PM
asianevo8's Avatar
P0500 and P0600
I have replaced my speed sensor on the trans, but all my gauges work any suggestions on where I should start?
Old Jan 20, 2013 | 04:26 PM
smai555's Avatar
i had to take the gauge cluster out, take it apart, and resolder 4 connecting points that are behind the speedo, there were hairline cracks in the solder if you have good eyes you can see it other wise you need a magnify glass to them
one of my other symptoms was cruise control didnt work
the reason why your speedo still works but you are getting a cel is because the signal goes from the tranny>speedo>ecu the signal from speedo to ecu gets broken up and throws a cel
its pretty easy if you have ever done soldering plenty of space, you just have to melt it and let it cool or you can make new ones connections if you know what you are doing
Old Jan 20, 2013 | 04:30 PM
maxfever1987's Avatar
You need a new electrical board for your cluster, wat year is your car? I have working clusters that I'm willing to sell u the board from, the board is highly easy to change it only has Phillip screws holding it in
Old Jan 20, 2013 | 05:40 PM
asianevo8's Avatar
I have a 96 thanks I will have to pull the cluster out and take a look
jchronis2552
Sep 21, 2015 05:52 AM
user 11122324
Jul 22, 2015 06:53 PM
artinfinitii30
Dec 1, 2014 12:34 AM
TRANK23
Jul 8, 2012 08:03 PM
dodoco
Feb 11, 2004 09:36 AM
