Wood Trim, peeling, solutions?, dash replace time?
Looking at a used '98. Great condition except for the dash wood trim, which is detaching itself, curling up, looks like total ****e. No way it can be re-attached - too much curling and surface damage.
What are the options? I'm assuming you can't just peel it, clean up the plastic underneath, and have it look fresh.
Are there aftermarket kits that are good? (pointers?). How about replacing the entire console and vent bits with some SE bits (I have a parts car potentially available) . How many hours of work would it be to swap the center console, the vents, and anything else that's wood now?
Thanks for any insight... I need to ballpark this job for time and expense.
Is this common? Do they all look pretty bad by now? Or does it depend on where the car was stored (like out of the hot southern sun)?
Any idea how big a job it is to swap?
Not too bad, though some attention to detail is required. I almost bought a 97 GLE and glad I didn't, I was already in priestess of finding the black SE interior trim to swap out.
It completely depends on how well the p.o took care of it.
This isn't just discolored... it's peeling from the bottom up. Really looks like heat damage to me - you'd think the care was a 'vert left out in the sun for years. I don't think the PO could do this if they tried.
If you are looking for OEM Wood Trims, for the 98 Maxima... let me know.. I might have something for you... need to know what pieces you may be looking for.
Best Regards,
Simon aka SYCEFIRO
sycefiro@yahoo.com
post pics definitely. sounds like youre talkin about ****ty aftermarket wood grain like someone else said. in which case peel it all off, clean up the glue, and start fresh. either vinyl wrap your oem trim, or water transfer it like some people do.
I dunno. Don't have the car here yet, but I'll check it out when I do. It sure looked OEM - except for the sections where it was peeling :-) Maybe they had a problem with the factory trim and replaced some of it with aftermarket.
Peel, sand, apply oem trim or paint I have heard good things about ceramic paint for the interior of the car, gonna try it myself one of these days...
It's a no-win situation, my wood went bad after only 2 yrs. (I bought my car new). They replaced it under warranty (whoa the first dealer accused me of installing it myself which is why it was peeling--wtf?? LOL). 2 yrs. later the same thing happened. Probably best to remove it imho. Those of you who aren't original owners of your car, that s*** was a $429 option if you can believe it!! p.s. if you look at "wood" trim on a German car, it's totally different, it's not pieces glued on, it's the entire fitted dash piece...Nissan did a bad job, but it is what it is...
Not sure why we take "high tech" mechanical devices made of plastic, aluminum, and steel and put wood (and sometimes fake wood) trim in them :-)
Ah... now we're getting there. The part that is peeling is on the vent area. Must be aftermarket. The factory stuff has a lot of discoloration, but it's not peeling. I think someone did a little "add on". I can probably peel that and be done with it.
I'll probably still swap it out for the black plastic since it doesn't quite hit my quality standards anymore.
vingodine
45
05-21-2016 12:46 PM
King_Ten_Ahead
09-30-2015 04:27 PM
kirkhilles
08-08-2015 10:53 AM
