High Pitched Squeaking Noise
Old Feb 2, 2013 | 12:52 PM
78Formula's Avatar
Hey guys, I've noticed a very high pitched squeaking noise coming from my car and I can't seem to find out what is causing it. I tried searching, but the first 5 pages showed nothing so I decided to create a new thread. The squeaking noise usually only occurs once the car has been driven for at least a few minutes (does not happen at start-up.) Once the car has been on for a few mins, the squeaking usually starts. It only happens when the car is idling in either drive or reverse. As soon as you give it any gas, it will stop and only start back once the cars goes back to idle. We put the car in drive and just let it run for around 10 mins. We noticed that the squeaking noise will stop about a minute or so before the fan stops and then it will start squealing a few mins before the fan kicks back on. It sounds similar to a vacuum leak, but we aren't certain. Any help would be greatly appreciated. Thanks in advance!
Old Feb 2, 2013 | 03:25 PM
Trini Boom's Avatar
Squeaks but it sounds like a vacuum leak? Hmm....what's the condition of the power steering belt?
Old Feb 2, 2013 | 03:51 PM
dsonnylal's Avatar
To rule out your belts being the culprit, grab some water in a bottle and while the squeaking is happening, pour the water directly on the belts. If the squeaking goes away, time to replace your belts.
Old Feb 2, 2013 | 09:30 PM
Snypa's Avatar
take the main belt off and start the car.
Old Feb 3, 2013 | 07:25 AM
billmus86's Avatar
while its squeeking- turn your wheel.- does it stop? =power steering belt
...im thinking its one of your belts-
they are cheap to buy, even right from the nissan dealer
Old Feb 3, 2013 | 09:54 AM
78Formula's Avatar
Thanks for all the help and suggestions guys. The power steering belt hasn't been changed since I've owned the car, which has been almost 3 years. Before that, I don't know if he'd ever changed it or not. We were planning on taking the belt off (just like Snypa said) but we ran out of time because I had to be at work that afternoon. I think the water bottle trick might be a good way to test it though. I'll try that and billmus86's idea to run out the power steering belt ASAP. If it still doesn't stop, I'll probably take the belt off and see what happens then. I'll keep you guys posted on the results.
Old Feb 4, 2013 | 08:21 AM
billmus86's Avatar
if youre going to take it off, just buy a new one haha dont do the same work twice..
i think it is like 20 bucks from the dealer for a new belt.. it was about 45 i think for both. ..ya know- might as well just change em and then you will be sure. -esp since youre thinking of just taking it off
Old Mar 24, 2015 | 04:57 PM
SteveSample's Avatar
High Pitched squeal
I have the exact same symptoms on my 1996 Maxima. I changed the belts and idler and still get the sound. It starts only after the Maxima warms up and sounds like it is coming from the power steering pump. The sound goes away once the rpm goes above idle. In the previous responses in the forum, no one seemed to identify the cause. Can anyone help? Thanks
Old Mar 24, 2015 | 11:49 PM
Could be a few things actually. I'll list them in order of likelehood IMO.
Tensioner pulley
Alternator pulley
AC compressor bearing
PS pulley and/or PS pump is beginning to fail
Also, check your crank pulley to see if the rubber is deteriorating. Look at the crank pulley as your car is idling to see if it 'wobbles' or if it spins true. If it's wobbling, it's throwing off the alignment of the belt.
Other things you can do...
Remove belt and spin pulleys. Listen and feel, you may be able to determine the culprit this way.
With belt on and car running, take a very long skinny tube and put it to your ear and touch a pulley or get really close to it (but be careful!). Whoever whines or makes the most high pitched noise is your culprit.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
