Suspension making squeaky noise
Old Feb 6, 2013 | 08:04 PM
strata400's Avatar
Whenever my car goes over bumps it makes squeaky/chirpy noises. Anyone have any idea what part of the suspension this is? Im hearing maybe bushings?
Old Feb 6, 2013 | 08:15 PM
Rasenganv3's Avatar
I've had the same problem. It turned out to be the shocks. If the car sways alot when going over bumps then that's most likely the issue. Good Luck!
Old Feb 6, 2013 | 10:56 PM
Snypa's Avatar
Control arm bushings.
Old Feb 9, 2013 | 04:21 PM
strata400's Avatar
Yeah my back end fishtails like crazy when going over bumps. Thanks a lot for the info! How much are replacement shocks?
Old Feb 10, 2013 | 09:26 AM
Rasenganv3's Avatar
The shocks themselves were about 70ea (local autozone), also make sure to check your mounts.
Old Feb 10, 2013 | 09:46 AM
ShocknAwe's Avatar
ok hold the phones here. Everyone has automatically assumed it is the shocks and there are literally 20 failed items that could make it squeak. If your shocks are bad you would be bouncing up and down for 30sec after each bump in the road. Is this the case? If not it is either your strut bearings or likely CA bushings
Old Feb 11, 2013 | 11:02 AM
cashoit's Avatar
Just look at the shocks from under the car...if they are leaking and rusty and decrepit , they are toast
Old Feb 12, 2013 | 03:36 PM
strata400's Avatar
Thanks for the replies guys, I will check it out tomorrow!
Old Feb 24, 2013 | 11:24 AM
99zx2's Avatar
also check your end links. if they are stock, replace them as they are most likely dead at this point. our car was making a squeak when the suspension would compress. turned out to be the end links.
alahjahwan09
18
Sep 21, 2015 09:12 PM
Violator
Sep 9, 2015 10:14 AM
A32goldylocks
Sep 2, 2015 06:39 AM
