Recommended Spark Plugs?
Old Feb 6, 2013 | 09:24 PM
BobMax's Avatar
What's preferred for replacement spark plugs? Original NGK PFR5G11 platinums? Are Bosch PLATINUM IR FUSION plugs OK or is it best to stick to the OEM?
Thanks,
Old Feb 6, 2013 | 09:29 PM
Fakie J Farkerton's Avatar
NGK or nothing.
Old Feb 6, 2013 | 09:48 PM
DennisMik's Avatar
can't go wrong with NGK.
Old Feb 7, 2013 | 12:34 AM
Rods03Max619's Avatar
Originally Posted by fakie j farkerton
ngk or nothing.
Originally Posted by dennismik
can't go wrong with ngk.
this
Old Feb 7, 2013 | 03:01 AM
EvoTillIDie's Avatar
NGK...You'll most likely NEVER hear or see anyone here say anything else. When they do it's because of a bad experience so they switch back to....*drum roll*...! NGK
Old Feb 7, 2013 | 01:17 PM
Divewjason's Avatar
The copper NGK V Power plugs worked like a charm on my '99 Maxima.
Old Feb 7, 2013 | 01:35 PM
njmaxseltd's Avatar
There's spark plugs in our engines?
Old Feb 7, 2013 | 03:27 PM
BobMax's Avatar
Thanks boys. I know from experience elsewhere that DI systems can be particular to the OEM plug... and maybe the coils last a bit longer with them.
It's OEM for me.
Old Feb 7, 2013 | 03:44 PM
kasso28's Avatar
NGK, like everyone else said. I just want to add, DON'T use bosch plugs in any Japanese cars.
Rasenganv3's Avatar
Is there really a difference between the NGK plugs themselves? Everyone says "NGK plugs are the best choice" but do the Standard, V-Power, G-Power, Laser Platinum, OE Laser Iridium, and the Iridium IX differ significantly?
Old Feb 7, 2013 | 03:51 PM
NmexMAX's Avatar
dot dot dot ...
Cu doesn't last as long, Pt lasts a little longer, IX lasts the longest. This question seems to have been answered before, I can recall.
I use copper since they're easy to change and are cheaper, and you get a chance to play with your car. If I had a penny for every time I've typed that on this forum, I'd be rich.
Old Feb 7, 2013 | 03:55 PM
Rasenganv3's Avatar
Thank you, but I was just curious if there was a noticeable difference between the G-Power ones and the Laser Platinum, which are both platinum plugs. So I'm guessing its negligible.
Old Feb 7, 2013 | 04:07 PM
dwapenyi's Avatar
Power difference is negligible.
Change interval difference is significant.
Platinums will last twice as long as coppers. Iridiums should last longer than plats, but twice as long?
Despite all that, coppers have the best electrical properties. They don't last but give one hell of a spark.
Old Feb 7, 2013 | 04:18 PM
Rasenganv3's Avatar
Thank you for clarifying!
Old Feb 7, 2013 | 04:41 PM
tosheto's Avatar
Used NGK V-power copper in few of my Maximas. Never had an issue.
Old Feb 7, 2013 | 08:12 PM
ct27gt's Avatar
I use coppers because they are the most conductive and I trust in the spark better than the other technologies. The change intervals also forces me to keep up on the maintenance of the car because I usually end up changing other maintenance items and checking things while I do them.
Old Feb 7, 2013 | 08:21 PM
Blue Mesa's Avatar
Punny!
MaxLvr21
Oct 17, 2015 12:11 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
