Replaced coolant temperature sensor. Now running "hot"
Old Feb 27, 2013 | 09:50 AM
pdpaiste's Avatar
Hey org. I just replaced my coolant temperature sensor that feeds to my gauge because it would have a sporadic panic attack every now and again. Now that I have the new one in, it shows that 'normal' operating temperature is 3/4's up the gauge (when it should normally be at half). Does this just sound like a possible fluke in the sensor itself? I'm getting a new one sent to me so hopefully it's just that one part. I'm pretty confident that it is the sensor because my fans aren't spinning faster than what would be normal. I also touched the hot coolant hose and it wasn't hot enough to burn me.
Let me know what you guys are thinkin. Thanks!
Old Feb 27, 2013 | 09:55 AM
Fakie J Farkerton's Avatar
OEM part needed.
I had an aftermarket that told me I was too hot also; and it wasn't even warm enough for the heater to work.
Factory part worked first time.
Old Feb 27, 2013 | 10:00 AM
Amerikaner83's Avatar
Originally Posted by fakie j farkerton
oem part needed.
I had an aftermarket that told me i was too hot also; and it wasn't even warm enough for the heater to work.
one hundred percent this
Old Feb 27, 2013 | 10:31 AM
pdpaiste's Avatar
Thank you fellas. I really appreciate your input!
Old Feb 27, 2013 | 11:12 AM
asand1's Avatar
My sensor was having the same panic stack, jumping around under hard acceleration and shifting. I soldered the terminal to the staked post it was loose on.
Old Feb 27, 2013 | 11:16 AM
to the OP - the same "OEM or bust" concept applies to the thermostat as well...so if you ever need to replace that, go OEM or go home
Old Feb 27, 2013 | 01:54 PM
dwapenyi's Avatar
You should replace the other coolant temp sensor as well, the ECT. It is the more important one because that one tells the computer how hot the car is so that the computer can then kick-in the fans.
Old Feb 28, 2013 | 06:34 PM
Trini Boom's Avatar
I think we need a thread for sensors that are "OEM or bust" until they are discontinued.
FlaMark
Aug 21, 2015 11:06 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Turbobink
Aug 17, 2015 04:11 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
