funny noise from EGR system?
Old Jan 12, 2002 | 11:15 AM
onefastmax's Avatar
My engine light told me that me EGR valve was bad. So I replaced it...turned uot not to be my problem. The light is still on after being reset and there is a funny suction noise with a ticking sound coming from some where on the right side of the motor. Has any body ever had this problem? Please help. Its expensive replacing unbroken parts...
thanks
onefastmax
Old Jan 15, 2002 | 07:03 PM
mo'max's Avatar
Re: Re: funny noise from EGR system?
Originally posted by rOaD bEaSt
I had this problem too but my nissan dealer was fixing that to me ..
If you play at the EGT valve this sound will come but I don't know how to remove that sound .
Did you check your EGR Solenoid? This could potentiallly be the ticking sound.
Old Jan 15, 2002 | 07:06 PM
Sprint's Avatar
check your spark plugs.. if one is really bad.. then your engine will give you that ticking sound
Old Jan 15, 2002 | 08:28 PM
95emeraldgxe's Avatar
ticking sound???? - i get a ticking sound when i turn off my engine....someone told me it was from the rims
Old May 17, 2002 | 08:58 PM
keener's Avatar
the ticking noise is the IACV, which is located by the EGR valve.
Old May 27, 2002 | 06:33 AM
mo'max's Avatar
If the sound occurs when the engine is off, I agree with keener that it is probably the iacv. Resetting the computer usually eliminates the ticking.
However the original complaint was that the engine code told you there was an egr problem. I found that a faulty egr solenoid can set off the ticking in the iacv.
Replace the solenoid and reset the computer.
shilov
Feb 19, 2024 09:40 PM
bumpypickle
Sep 19, 2015 01:07 AM
lrb6805
Sep 17, 2015 04:49 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
