any clue on on this sensor on the tranny?
Old Mar 14, 2013 | 04:46 PM
maxima2fst4u's Avatar
hey guys got a question while im taking my tranny back out to sand the housing down and the motor where they mate together...notice a little black square sensor on the driver side of the transmission close to the back...it has 2 wires jw if anyone knew what it was for cause its not even plugged in due to the plastice connectors are broke
Old Mar 14, 2013 | 05:11 PM
its an automatic if that helps any and has one bolt that holds it on and no its not the speed sensor
Old Mar 14, 2013 | 05:18 PM
ShocknAwe's Avatar
somebody else had this question. I looked it up in the FSM but I cant remember what it was. CHeck there
Old Mar 14, 2013 | 05:32 PM
BlackThornDemon's Avatar
You better get a new connector. That's your dual powertrain hyper capacitor. Car wont run without it.
Old Mar 15, 2013 | 02:21 AM
wow really been running good for 2 years unplugged and when i plug it up i should be able to travel back in time to right!!! idiot
and for the other reply ok ill def look it up cause its not been plugged up since my last trans swap..im doing the sanding down trans and block deal to quit this no start bs i've got just realized it after replacing every sensor on it lol didnt sand it down none when i done the swap and it set a day or 2 with no tranny so i know there is build up on it oil what ever dirt grime deal you know
Old Mar 15, 2013 | 03:11 AM
2brosgixxer's Avatar
You able to snap a pic of the sensor? If the hyper capacitor is unhooked, that's no biggie, you need the FLUX capacitor to go back in time
Old Mar 15, 2013 | 04:36 AM
njmaxseltd's Avatar
Your wasting your time with the sanding process.
Old Mar 15, 2013 | 05:32 PM
I disagree. My clutch was replaced and the tranny was not cleaned up before re-install. Had them pull it back out and clean it and it fired right up.
Old Mar 15, 2013 | 06:11 PM
agreed i didnt do jack to cleaning mine off and i know it had been nasty from my hands and dirt and mudd on it so its that deal...for nissan to hook it up and tell me theres nothing wrong with my car after i replaced every sensor on it..yea taking it back out....didnt start this till a week after the tranny swap but has just gotten worse lately figured why not since i have some time on my hands you know...
Old Mar 15, 2013 | 09:12 PM
Cielo's Avatar
its a well known sensor in the S14 crowd of 240s.
the black square with 2 prong plug on the bell-end of the trans with a black tiny cylindrical thing coming out on the inside, right?
this is the CAS/ Crank angle sensor. it comes on obd2 cars and some 94.5 model nissans. for S14 people tryna do tranny swaps its a way to properly identify if your getting the right trans from the buyer or if they are scamming you with an S13 trans.
all it does is, well, its job. and keep you from throwing a CEL. it is not a vital component since nissans prior to 94 except the GTR had no such sensor.
idk if it affects the CEL throwing on A32s. but that is what it does for kouki 180s, S14s and 15s. unnecessary
Last edited by Cielo; Mar 15, 2013 at 09:17 PM. Reason: erasing some cocky unnecessary bs
Old Mar 16, 2013 | 06:22 AM
njmaxseltd's Avatar
I believe your referring to Crank Position Sensor (position) which is located on the bell housing under and towards the front of the car. The other Crank Sensor (reference) is located just above the main pulley.
Both sensors are on all 95 and up VQ's. A no start condition will result if CPS POS fails. Those are the only 2 crank sensors on the A32.
Old Mar 16, 2013 | 07:02 AM
Nugent20's Avatar
Crank and can sensors throw car into fail safe, or limp mode I thought...not a no start?
Only asking cause this happened to me last week when a Cam sensor filled with agua
and I could be wrong, but I swear that sensor on my tranny has only 1 wire and is related to a ground
Old Mar 16, 2013 | 07:04 AM
Nugent20's Avatar
and +1 on the sanding. I read about that after my swap, and just added a ground to the starter and tranny (4 ga.)
No problems since
Old Mar 16, 2013 | 09:11 AM
max ride 41's Avatar
that was your flux capacitor, you won't be able to hit 88 mph and travel through time.
Old Mar 17, 2013 | 06:38 AM
njmaxseltd's Avatar
CPS REF and the Camshaft position will throw it into fail safe.
CPS POS will cause a no start.
Old Mar 17, 2013 | 07:15 AM
digitalbow's Avatar
I cannot believe you got this many idiotic responses. The only sensor on the AT or MT that, if disconnected, will not cause a 0700 series DTC or no-start condition is the reverse gear sensor. In accessory mode, set your parking brake and put the gear selector in reverse. No illumination of your reverse lamps indicate a break or fault with this circuit.
my03maxima
Jul 28, 2024 07:40 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
