No Start BS IS FINALLY FIXED
Old Mar 28, 2013 | 12:34 PM
maxima2fst4u's Avatar
after a year of replacing sensors and starters my problem is gone..started it up 40 times in a roll with no catches or drags just smooth VROOOM lol after 4 hours taking the trans out and using a wire wheel and some sand papering the matting surfaces of the trans and engine its finally fixed thank god now i can get my painting and back to my 3.5 build for it in the building
Old Mar 28, 2013 | 12:48 PM
digitalbow's Avatar
If you don't post the resolution in the original thread, it's of no use. http://forums.maxima.org/4th-generat...-start-bs.html
Old Mar 28, 2013 | 05:03 PM
It's well documented that a bad tranny ground will cause this. Surprised you didn't get the answer easier and much sooner w/o spending so much time, money and effort.
FWIW, you didn't even have to go through all that work. A 50 cent cable from the tranny to the battery ground would have done the trick.
Old Mar 28, 2013 | 05:10 PM
no i actually ran 3 wires to the transmission to try and fix it and nothing one to the starter bolt one next to my crank sensor and one on the back side didnt do nothing...so needless to say 50 cents wouldnt have fixed my issue wish it would have but its all good now....i can get back to my 3.5 build in my garage i knew it was a ground issue due to how it was acting and stuff just never really had time to do it with work kids wife and everything
Old Mar 28, 2013 | 05:13 PM
Well, the 50 cent trick worked on two of my buddies maximas...Both of them had tranny work about a month before the starting problem reared its ugly head. I wonder if there is a 'correct' tranny grounding point now? hmmmmm....I'll ask my buddy tonight.
Old Mar 29, 2013 | 10:14 AM
yea i wish it had of lol woulda saved me 4 hours of work lol but its all good i tried everything for grounding even grounding the black wire on the crank sensor the one thats on the tranny and nothing acted like it wanted to but nothing but an hour on a wire wheel was worth it now no worries
Old Mar 29, 2013 | 01:28 PM
Max_Gator's Avatar
Its all about finding the correct grounds. I had that problem when I replaced my clutch and had to experiment on the ground points.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
iflexsteel
Sep 2, 2015 08:04 AM
