P0135 Bank 1 Sensor 1 Cali spec
Old Mar 31, 2013 | 08:54 AM
gladiator's Avatar
So I'm looking to replace the o2 sensor of my 99 SE Cali Spec
This is what I found from searching the forums:
Bank 1 is located next to the firewall Cylinders 1,3,5
Bank 2 is located towards the front of the vehicle Cylinders 2,4,6
Where is there an o2 sensor by the firewall? Which one am I supposed to replace?
And are there a big difference between the fed spec and cali spec o2 sensors? I don't want to buy the wrong one.
Old Mar 31, 2013 | 10:20 AM
SterlingMistMax's Avatar
you would have to get under the car to see it . there is 4 on the cali spec cars . sensor 1 is the one closest to the motor . there is different numbers for the fed spec one. this link will take you to a diagram its for the 2000 max but its the same for the cali spec max (99) . http://forums.maxima.org/4th-generat...-pictures.html
Old Mar 31, 2013 | 11:01 AM
DennisMik's Avatar
Here is a link to a picture of the y-pipe. It is from the 5th gen forum but your 99 is the same for this. Scroll down about 3 screens for the picture.
http://forums.maxima.org/5th-generat...on-issues.html
Old Apr 1, 2013 | 08:08 AM
gladiator's Avatar
thanks, lifesaver as usual.
As for the sensor, should I get an universal fit where I have to splice the wire? Or just one with a harness should be easier and worth the price
Something like this at Autozone:
Part Number: 15726
Warranty: 1 YR
Application: With California emission
Left up-stream sensor (located before catalytic converter)
Notes: Universal fit
Old Apr 1, 2013 | 08:12 AM
Been using the NTK(maker of NGK plugs) ones myself and they are direct fit .
Old Apr 1, 2013 | 11:33 AM
asand1's Avatar
rockauto.com is about half the price of AZ.
STANDARD MOTOR PRODUCTS Part # SG285 $35.79 +shipping
The one I bought was boxed Standard, but made and stamped by NTK.
Old Apr 1, 2013 | 11:40 AM
gladiator's Avatar
sweet! I'll go Rockauto route then. Killer deal
Old Apr 1, 2013 | 12:04 PM
gladiator's Avatar
also, would a bad KS would cause excess fuel to be unburnt and mess up the o2 sensor?
I don't want to replace the o2 sensor before changing out the KS and have it foul up again.
Old Apr 1, 2013 | 02:23 PM
asand1's Avatar
Negative, in fact the KS is a likely ghost code caused by the bad O2. Replace the O2 and clear the codes.
There is a chance both are legitimately bad, but the O2 code will ALWAYS trigger a phony KS code.
BTW $7 Ebay Knock sensors work well and have not proven to be any lesser quality than OEM.
Old Apr 6, 2013 | 04:41 PM
gladiator's Avatar
wow turned out that was the most difficult one to access. I still couldn't see and follow the harness on the way up.
Is the connector for Bank 1 Sensor 1 near the firewall by the first coil? If count starting from the passenger side
This should be the same location:
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
hayne
Oct 5, 2015 11:53 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
zmcneely13
Sep 26, 2015 02:26 PM
