97 gxe auto no start
Old Apr 3, 2013 | 06:32 PM
TurboA32's Avatar
Ok I have a 97 gxe auto and it needed a new engine. So I swapped it out and it didnt want to start. so I did my trouble shooting and I found I wasn't getting any spark. So I pulled the transmission off and sanded the mating surfaces on the transmission and the engine. I changed the battery negative side and ground wire with brand new one's and I added a ground to the transmission to the body of the car and still no start. So I sprayed starter fluid in the manifold and it started a little bit but not all the way and when im cranking it I have 0 rmp??? I changed crank sensor in the front of engine/transmission still same thing. What would cause the 0 rmp problem??
Old Apr 3, 2013 | 07:27 PM
BlackThornDemon's Avatar
Bad ECU?
Would explain no spark and 0 rpms.
Old Apr 3, 2013 | 07:33 PM
TurboA32's Avatar
It gets rpm when I spray starter fluid but after the engine dies down its 0 rmp after that. So you think a bad ecu?
Old Apr 4, 2013 | 05:36 PM
TurboA32's Avatar
This ever happen to anyone?
Old Apr 6, 2013 | 08:58 AM
TurboA32's Avatar
Guess not......but before I pulled the transmission and sanded the mating surface I got rpm on crank. I dont hear the fuel pump prime at all even after I swapped it out with another one.
Old Apr 6, 2013 | 08:31 PM
TurboA32's Avatar
I checked the egi relay and the fuel pump relay and theres power going to them.......im stumped
Old Apr 7, 2013 | 09:32 PM
TurboA32's Avatar
Any help would be nice.
Old Apr 8, 2013 | 10:38 AM
98seW/DaBUMP's Avatar
ignition switch or relay? i know that the cam position sensor will keep you from turning over i dont think it will pop up a CEL but if you check your codes you could see if that is the problem. it sounds like your problem is something electrical that isnt connected or has a bad connection. clean your MAF as well just because.
markevans999
Oct 25, 2015 08:27 AM
97_GXE
Sep 15, 2015 06:47 AM
rnb754
Sep 14, 2015 11:39 PM
trungg86
Sep 4, 2015 04:58 AM
