Shocks and brake help
So my front shocks, as well as my pads and rotars have gone to ****. I would like to attempt to do my front brakes and front shocks using the guides on the sticks in the how to's, but I want to see who has done them first before I start just in case. So who here has actually done this before and not look over the page 5 million times like me? Lol
Yes I was planning on it. I just simply want some feedback from someone whose done their fronts like in the how to's (or without for the matter) just so I know if there are any problems I'm likely to run in to.
I did as well... you will need to get spring compressor tool for "coils" from Advance Auto/Autozone or other stores that offer them for rent and few wrenches and maybe a pipe for leverage, as bottom bolts might be hard to get off
got something even better for you - http://www.vbxmaxima.8m.com/shocks.html
Make sure to replace all rubber parts on the struts, might as well since you are there. Its a fairly easy job to do. Make sure you have all parts needed before starting the job.
Get your self a breaker bar if you dont already have one to get the two strut bolts off. One of mine was so rusted on that I snapped two sockets and an extension. PB blaster also helps to get the most stubborn bolts off. Get yourself an alignment after a strut job. Dont listen to others that say you dont need one Or you will see your front tires fade away in the wind. Ask me how I know this.
Brakes and rotors are really easy as well. Follow the how to's and the advice of others and you will be just fine.
For springs, I'd recommend a clamshell type spring compressor and for rear calipers you need a good tool to turn in the piston. The front caliper pistons are much easier to reset.
i replaced my front and rear suspension yesterday.
its not hard, get a spring compressor from advanced auto parts, rent it out for like 52 bills. if u have air tools the whole process will take no more than 2 hours. i didnt, took me like 6, with all them rusty bolts.
so for front, take off the wheel, remove 2 bolts that hold the strut in the axle im guessing, then remove the top 3 bolts under ur hood, take out the strut, compress the spring, take off the top bolt, remove strut mount, take out the spring, put the spring on the new shock( make sure that while ur removing/ tighting the strut mount bolt u clip the shock with like pliers and.... umm w.e just make sure the shock doesnt spin while ur tightening/loosing the strut mount bolt, cause if u move it too much seals break and ur shock will leak out. also while takin out the strut from ur car or putting it back in dont be afraid to twist ur axle around to make it go in/come out
04-16-2020 05:15 AM
HerpDerp1919
09-29-2015 02:02 PM
