Signal Indicator Problem
Old Apr 21, 2013 | 08:39 AM
Trini Boom's Avatar
Org, I think I have a rare problem here with my indicator system. When I signal to turn, it works normal and at random, it turns off and stops working. This occurs when I signal left, right, or turn on the hazard switch. I would hit the dash or the steering column and it would start back working briefly and then go back out. Is this a tired relay that needs replacing? If so, where is it located or someone guide me in the right direction.
Old Apr 21, 2013 | 08:47 AM
pMax6r's Avatar
Mine did this for the first time last night. I turned my turn signal on and it didn't even blink. It just turned the dashboard arrow light on and never worked. I didnt know what I did to make it work again, but I was so confused. I'm not an electrical guy, so anyone else with input would be so helpful.
Old Apr 21, 2013 | 09:52 AM
Fakie J Farkerton's Avatar
Try an new hazard switch?
Maybe swap out the flasher under the dash..?
Old Apr 21, 2013 | 01:28 PM
Trini Boom's Avatar
Is there a diagram of the circuit in the FSM? Rather narrow it down to the exact problem instead of changing random parts. I can try the hazard switch though since I already have a spare one.
Old Apr 21, 2013 | 03:02 PM
pmohr's Avatar
No more Maximas...
Of course. There's not a circuit in the vehicle not described in the bible:
http://boredmder.com/FSMs/Nissan/Maxima/1996/
Old Apr 21, 2013 | 04:52 PM
Trini Boom's Avatar
^^Jesus.....I think I am going to start with the hazard switch. I would have never imagined the circuit for that was so complex. Also M34 (Combination Flasher Unit) may be a point of interest. Where is that located?
Old Apr 21, 2013 | 05:09 PM
njmaxseltd's Avatar
OP - replace the flasher relay under the dash.
Old Apr 22, 2013 | 02:48 PM
Trini Boom's Avatar
njmax, do you know where it is located??
Old Apr 22, 2013 | 03:05 PM
Amerikaner83's Avatar
I do. It's under the steering column above teh drive's right knee. Little cube with three prongs, like an electrical outlet
Old Apr 22, 2013 | 03:09 PM
Trini Boom's Avatar
Thanks man. I will go and look for it and see if I can get it swapped out. I will update and take a pic once I get a replacement.
Old Apr 22, 2013 | 03:10 PM
if a new flasher relay doesn't work, I'd look to the actual turn signal switch next.
Old Apr 22, 2013 | 07:52 PM
Says Nabco on it and has its own mounting bracket held in by a 10mm.
It is a lot easier to unplug if you unbolt it.
Old Apr 23, 2013 | 03:13 AM
dwapenyi's Avatar
Originally Posted by pmohr
Nice to see you around....LOVE your How to videos.
Old Apr 23, 2013 | 04:44 AM
DennisMik's Avatar
Old Apr 23, 2013 | 12:08 PM
cashoit's Avatar
Gotta love electrical circuits .....
Old May 26, 2013 | 05:37 PM
Trini Boom's Avatar
Update
Just to update the thread, I ordered the part from dealer which was service filed with a redesigned part and the bracket had to be swapped. Here is the photo of parts ordered.
The new unit is smaller then original and after installing, it is a little quieter when signaling. So far, it is working but will not know for sure until I do a highway trip. Will keep you guys posted.
chernandez1278
Sep 16, 2015 01:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
Maxxx10
Sep 13, 2015 03:16 PM
