all 3 speakers out on R side bose
I've put 2 different HU's in and with both the whole right side doesn't work. I was wondering is this common? Is there a fuse for just the right side? The 3 speakers on the left all work fine with both HU's but appears like the right channel may be blown..![Confused](https://maxima.org/forums/images/smilies/confused.gif)
This is on my 95 with Bose.
There are no fuses specifically for the left or right channels in the Nissan wiring. If you are certain that the 2nd head unit is good, the wiring has a problem.
What you might want to do is check the red wire on each speaker (except tweeters) for 12 volts when the the radio is on. But all this will tell you is if this one wire is good. You need to check continuity on all the wires for the right side.
03-12-2020 12:06 AM
popdedop
09-11-2015 11:17 AM
