Problem starting
Old May 19, 2013 | 04:44 PM
odawg23's Avatar
Problem starting
ive search around but can find a definite answer. Last night i tried to set up a keyless entry remote, ended up not working. The red security light stayed on which i found weird cuz it never stays solid. went home car started fine. on my way home randomly my radio turned off on its on. This morning I went to turn the car on and it was rough but it started. the power in the car was slightly different the wipers seemed slow the lights in the car seemed dimmer than usual. so i parked and went to check fuses everything was fine, i go to drive off and the car didn't start. kinda like a dead battery.. i tries to crank on but it dies out after like 2 cranks. got someone to give me a jump and it started almost automatically. i went to buy a new battery. turned off the car and everything. installed new one turned on beautifully, all lights bright radio works good. went to the mall parked for like 2 hours. i get back home turn off the car, i decided to check if itll turn on just to reassure myself. and then boom, nothing same as before...alternator? starter? idk...ive had 0503 code for like 3 days now...o2 sensor? could this affect it?
Old May 19, 2013 | 04:48 PM
Aflion's Avatar
Sounds like alternator. Did the battery and brake light ever turn on while you were driving?
Posted from Maxima.org App for Android
Old May 19, 2013 | 04:53 PM
odawg23's Avatar
all i have on is the cel 0503 besides that nothing else has turned on
Old May 19, 2013 | 08:19 PM
EvoTillIDie's Avatar
It's your alternator for sure.
Old May 20, 2013 | 10:10 PM
kctyphoon101's Avatar
its very easy to check if its the alternator before you go out and buy one.. start the car, or jump the car if you have to, and disconnect your battery while its running. if the car dies as soon as you disconnect your battery, then yes your alternator is shot. if the car keeps running, then you have something else going on. probably a short somewhere, or something draining the battery.
easy way to see if thats the case is to throw a voltmeter on the terminal while the car is off and see if there is something drawing power. there will always be a very small draw of power, which im sure someone can tell you what it should be, but if your battery keeps dying, then you would have something noticeable showing up on the meter.
if this just started, and you just screwed around with some wires, then i strongly suggest you go back and look carefully at everything you touched.
Old May 21, 2013 | 01:44 AM
Accord4tehloss!'s Avatar
Do not disconnect your battery while the car is running... you have a high chance of messing up your ecu and other sensitive electronics.. that test used to work on old cars but does not on modern cars.
Old May 21, 2013 | 02:27 AM
Climaxx's Avatar
4th gen max can be considered as an "older car"
Plus when the car is running, battery is useless anyways.
Old May 21, 2013 | 06:24 AM
Aflion's Avatar
Yup. Disconnecting the battery wont harm it as long as the ground is still connected. Thats how I checked mine when it died.
Old May 26, 2013 | 03:11 PM
odawg23's Avatar
i had actually left the negative terminal loose by accident and it popped out and car died almost instantly, anyways i changed it and my baby running good again no starting problems...but god damn was that last bolt in the back of it a pain in the *** lol i also removed the fans and moved the A/C compressor out of the way it helped a lot by doing that for the last bolt
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
