Should I get my brakes checked ?
Old Jun 6, 2013 | 10:28 PM
Diamons's Avatar
It was raining on the heavier side today in NYC and I was driving on a ramp going down at 40 mph. I tried to hit the brakes but when I pushed down my car would make a sound and my foot would sink in but no break. I basically couldn't brake as fast as I'd like and almost hit a can within inches. There were noises coming from the front of the car at the same time.
I'm kind of still in shock. When I drove on flat roads I could brake quite easily.
Any idea what happened ? This happened twice when I tried to replicate it going down the ramp again a while later.
Old Jun 6, 2013 | 10:43 PM
Aflion's Avatar
That sounds pretty scary. I'm glad you're alright.
Yes, check everything in the system. Whether you do it yourself or have someone else do it, it all needs to be gone through.
Posted from Maxima.org App for Android
Old Jun 6, 2013 | 10:53 PM
WendysMaxima's Avatar
^this. Check the whole setup, if it's out of your league, go to shop. A few guys on here might know what's up but if that's in your daily drive, I suggest going to a shop asap.
Old Jun 7, 2013 | 01:33 AM
DennisMik's Avatar
Since it happens on an incline, you may be extremely low on brake fluid. But if you are low on fluid, the red brake light in the instrument cluster should be on.
Old Jun 7, 2013 | 05:40 AM
njmaxseltd's Avatar
The noise is called ABS, slow down on wet roads.
What condition are you tire in?
Old Jun 7, 2013 | 11:13 AM
jdooley's Avatar
I think njmaxseltd is correct. If you've never experienced an ABS system engaging then it can come as quite a shock. Try the ramp test again when the roads dry out and see if it's normal again.
Old Jun 7, 2013 | 09:56 PM
Trini Boom's Avatar
Yes and is your ABS light on? If so, the ABS system is disabled if a sensor is malfunctioning. Also, I would hope that you stopped by using your e-brake or is that not working also?
Old Jun 15, 2013 | 10:10 PM
PasswordIsTaco's Avatar
Sounds scary. I'd check the whole system for sure
Mar 12, 2020 12:06 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
crazyespn
Sep 3, 2015 01:30 PM
A32goldylocks
Sep 2, 2015 06:39 AM
