Need to replace wheel bearing - how to do it?
Old Jun 18, 2013 | 06:31 AM
matts95max's Avatar
I have had wheel bearing problems for years. Seems that they always go bad. Ive swapped in whole spindles without replacing the used bearing and Ive had nissan put in new bearings. Seems to be a never ending problem. My axle nuts have come loose a couple times too.
Anyway, passenger front needs a new wheel bearing. I thought about replacing the bearing and hub assembly together. Looks like rockauto.com has some hub assemblies already put together?
Which brand hub/wheel bearings should I buy? Should I buy local from a parts store or online? What all should I replace?
Thanks for the help.
Matt
Old Jun 18, 2013 | 11:01 AM
matts95max's Avatar
well just bought a hub and wheel bearing off rockauto.com. timken bearing and dorman hub.
Old Jun 18, 2013 | 11:14 AM
Amerikaner83's Avatar
all the hub/bearing assemblies I've found on rockauto are for the rear...did you buy separate or as one assembly?
Old Jun 18, 2013 | 12:08 PM
matts95max's Avatar
yeah I saw the ones for the rear. They are separate for the front and they have to be pressed together.
Old Jun 18, 2013 | 12:09 PM
damn, was kinda hoping we could get the entire assembly. I may have to make a purchase like this very soon myself
Old Jun 18, 2013 | 12:12 PM
matts95max's Avatar
Yeah I wish it was already assembled too. Less room for error on my or a shops part pressing it together.
Old Jun 18, 2013 | 12:16 PM
yeah...you've got a loud humming sound going down the road upwards of 40mph, yes?
Old Jun 24, 2013 | 10:02 AM
matts95max's Avatar
So I got the wheel bearing in that I ordered online and it is not sealed... I ordered the Timken 510009 from RockAuto.com
When I took the new hub/bearing to the shop to have it put into the spindle, the mechanic told me that the bearing wasnt sealed and wouldnt last long at all. So I went and bought a National sealed bearing from Advanced.
Should all the wheel bearings be sealed? Or do people use unsealed wheel bearings?
Old Jun 24, 2013 | 10:05 AM
I'm not sure but I was thinking of that exact same timken bearing off roackauto...
Old Jun 24, 2013 | 10:38 AM
asand1's Avatar
The seals press into the knuckle after the bearing and snap rings are in.
Old Jun 24, 2013 | 11:30 AM
matts95max's Avatar
This bearing didnt come with any seals to press into the knuckle.
Old Jun 24, 2013 | 11:35 AM
Max_Gator's Avatar
I suggest Timken. I got both bearing and hub at autozone for like 190. I had a complete failure so I couldn't wait.
What I did was disassemble everything and take the knuckle to a machine shop and have them press in and out the bearing and hub. Cost me $35.
This is one of those things that you really need a press to do correctly. There are instructions out there to do it without one. But, for what I paid, it was a no brainer.
And I don't know what seals you guys are talking about. AFAIK there is the hub, bearing and snap rings.
Old Jun 24, 2013 | 11:43 AM
The seals are 40232 (11 bucks each), one on each side of the bearing assy (40210). Snap rings (5 bucks each) are 38514
This is from nissanpartsasap.com. NEW OEM bearing AND HUB (40202M) are 120 total.
Old Jun 24, 2013 | 11:58 AM
asand1's Avatar
You buy them separately.
Old Jun 24, 2013 | 12:08 PM
Max_Gator's Avatar
Hmm...I wonder if they reused my seals or if the Timken set actually came with them.
Old Jun 24, 2013 | 12:47 PM
matts95max's Avatar
Oh! you are talking about the inner and outer grease seal. Yeah I bought and used a new inner seal.
But I am talking about the bearing itself being sealed. Ill try to get some pics. I just went ahead and bought one that was sealed and called rockauto to return the unsealed timken one.
Old Jun 28, 2013 | 11:54 AM
maxinout93's Avatar
the only seals I know are the inner and outer gease seals that keep the dirt out and the wheel bearing grease in so that it lasts longer.
Old Jun 28, 2013 | 12:00 PM
unless he's talking about the bag itself that holds the bearing being sealed or not The one I got at AutoZone wasn't..timken bearing
Old Jun 28, 2013 | 01:21 PM
dsonnylal's Avatar
Bought the timken bearing as well, along with two new seals. Got the old one pressed out, new one pressed in. Problem solved. Would've been a one day job, but my ABS sensor played difficult and had to be replaced.
boomerbrian
Nov 8, 2015 05:10 PM
seesole
Aug 26, 2015 11:22 AM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
