Cam/Crank/knock sensor codes.
Old Jun 24, 2013 | 12:40 PM
Crusher103's Avatar
Issue is the car continually throws the same cam&crank sensor codes over and over again. This is accompanied by stumbling, hesistation and misfires. The sensors are not the problem nor is the harness. Tested them and replaced them both new and sensors from fully functioning cars along with putting my old sensors on to working cars for them to not throw a single code about that.
The car keeps throwing these codes and im wondering what is causing it to do so. It seems as if i have some other electrical issue that needs to be addressed. Any ideas.
Old Jun 24, 2013 | 01:06 PM
Amerikaner83's Avatar
did you do the grounding like I mentioned in the newest new new newer thread? YOu keep pulling motors / transmissions that mating surface is crucial to get yoru motor a good ground...electronics do weird things if they don't have a good ground plane
Old Jun 24, 2013 | 01:37 PM
Crusher103's Avatar
I did do the grounds, im wondering if there is something else im missing. to cause all 4 of those sensors to throw codes and the driving issues.
Old Jun 24, 2013 | 01:56 PM
cjandura's Avatar
Does their harness share the same ground?
Old Jun 24, 2013 | 02:10 PM
MoncefA33's Avatar
Replace the ECU.
Old Jun 24, 2013 | 03:39 PM
cjandura's Avatar
Replace Car with Little Rascal Scooter or Adult 3 wheel Tricycle
I been saying this for months now!
Old Jun 24, 2013 | 06:59 PM
Crusher103's Avatar
Replace the ECU.
tried the ECU same issue persist.
Old Jun 25, 2013 | 07:14 PM
cjandura's Avatar
Broham i found the issue!it was so simple and right infront of us!The Problem is You! Your working on the car unsupervised and you proboly put the sensors in the wrong holes just because you have a track record of using the Wrong Holes.......so take the car down the road to the nearest 16yo kid and have hime fix it for you or drop off at pepboys youll get the same results out of either.
Old Jun 25, 2013 | 07:15 PM
Fakie J Farkerton's Avatar
been waiting for this.
Old Jun 25, 2013 | 09:04 PM
Trini Boom's Avatar
dear god!!!
Old Jun 27, 2013 | 03:00 PM
cjandura's Avatar
He is now hiding from the truth!!!!
Sent from my iPhone using MaximaOrg
Old Oct 22, 2013 | 11:36 PM
JIWebby's Avatar
4th Gen
I've got a 4th gen maxima that is doing the same thing. Camshaft position sensor, and knock sensor codes. At high speeds when it's warm it knocks.
I was told by a shop in town that it's one of the oxygen sensors causing it. The same shop said they were covered up with work and can't get to it right now. When of find out more..
I hope this might help.
Old Oct 22, 2013 | 11:41 PM
Originally Posted by JIWebby
I've got a 4th gen maxima that is doing the same thing. Camshaft position sensor, and knock sensor codes. At high speeds when it's warm it knocks. I was told by a shop in town that it's one of the oxygen sensors causing it. The same shop said they were covered up with work and can't get to it right now. When of find out more.. I hope this might help.
Welcome to the org!
Go by your local auto parts store and get your codes scanned.
You can use a wrench or an o2 sensor removal tool if one of your o2 sensors are bad.
Pretty much any brand, I like NGK.
Not too hard, especially if your fed spec.
Fed spec has two upstream and one downstream.
Not sure on the Cali spec, but the FSM in my sig is invaluable.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
