Alternator fried?
Old Jun 28, 2013 | 02:51 PM
granturissimus's Avatar
Alternator fried?
My dad's Maxima has been making little shakes for the past week when he'd be at red lights. It's an automatic. It's a shake as if a spark plug is not firing for a fraction of a second. They were fragmented shakes. Today on the freeway it was really bad, as if the engine is shutting down, major shakes. Then on the streets, the car just stalled.
Some guy came with his car to jump start the car. My dad is not sure how the guy connected the wires to my dads car, but the car did start... once it started the guy did not disconnect the cables, and my dad was reving the engine and smoke started coming out of the left side of the engine... left as in the area with the belts. It was burnt smelling smoke.
My dad got home and started the car after charging the battery. Once the car was running he disconnected one connector from the battery, and the car engine stalled. He says the generator is broke. Is the generator called "alternator"? Not sure about terms.
What do you think is wrong?
Old Jun 28, 2013 | 02:58 PM
Amerikaner83's Avatar
sounds that way, yes.
Old Jun 28, 2013 | 03:03 PM
why do you think so? the guy only connected the + cable to the battery, and the minus he connected to some other part in the car, and he didn't disconnect the cables after the car started... is that what fried the alternator?
no. That sounds right, + to battery, - to frame
The alternator died BEFORE your dad got the jump...the jump was not the cause of the alty going poof. It's not that uncommon on the 4th gen.
Old Jun 28, 2013 | 03:05 PM
which is it...your dad knows how the wires were connected or he doesn't?
Old Jun 28, 2013 | 03:11 PM
He saw the guy connect the minus to the bolts that connect to the shock absorbers (sorry totaly clueless about part names), then he disconnected the minus, and connected it somewhere on the engine... my dad did not see where exactly he hooked it up on the engine.
Old Jun 28, 2013 | 03:19 PM
Can it be fixed by replacing a fuse or brushes?
Old Jun 28, 2013 | 03:30 PM
Nope
Old Jun 28, 2013 | 06:50 PM
can someone recommend a good alternator? He has the 98 SE Maxima. Don't want a really expensive one though.
Old Jun 28, 2013 | 08:59 PM
gruesome's Avatar
The former online bookseller named after a river in south America,
Old Jun 28, 2013 | 10:37 PM
Fakie J Farkerton's Avatar
Originally Posted by gruesome
the former online bookseller named after a river in south america,
dafq?
Old Jun 28, 2013 | 10:56 PM
PowerTotheMax's Avatar
Amazon? Lol 2nd time I see thst
Old Jun 28, 2013 | 11:05 PM
Trini Boom's Avatar
This guy is stoned...
Old Jun 30, 2013 | 02:03 PM
How can I be sure that it is in fact the alternator that's broke? There are no warning lights that show up in the instrument panel (they all light up for a second during start then turn off). But like I said, if he disconnects the battery while the car is running, engine stalls right away. Is that a sure sign the alternator is broke?
Old Jun 30, 2013 | 02:42 PM
bprice92's Avatar
When mine failed both the brake and battery dash lights would stay lit while the engine was running.
Old Jun 30, 2013 | 07:39 PM
I read the codes with the check-engine-light-blinking method, these are the 3 I got:
0504
0101
0304
I know 0304 is knock sensor which we been meaning to change. But what about the other 2?
Could these codes have something to do with the engine stalling once battery is disconnected?
Old Jun 30, 2013 | 09:39 PM
tosheto's Avatar
Measure the voltage at the battery with multimeter. It should be around 12.5V with the engine off. It should be about 14.5V with the engine running. If it shows less with the engine running you need alternator. I wold get one from autozone. Lifetime warranty.
Old Jul 1, 2013 | 10:12 AM
We did this today, and the voltages were just like you said... so the alternator WORKS.
Today my dad took out some big fuse and but it back in... it was not fried. And the engine ran even after he disconnected the battery. Then he turned the engine off and tried to do the same thing, but the engine stalled once again.
Perhaps those 2 other codes have something to do with this? 0504 and 0101. Here they are:
Code: P0340 | Description: Camshaft Position Sensor
Code: P0600 | Description: A/T Comm Line
***UPDATE: These 2 codes are now gone, and only the knock sensor code remains.
Old Jul 1, 2013 | 02:19 PM
tosheto's Avatar
Well, check the Camshaft position sensor and it's wiring. That could cause the problem.
Old Jul 1, 2013 | 03:44 PM
Those 2 codes don't show anymore. Also, the voltage at the battery when the car is running is 14 volts, not 14.5.
BUT, what we noticed is that when we start teh car, and turn on the stereo, and while the stereo is on we disconnect the battery... the engine keeps running for about a minute WITHOUT the battery connected. After about a minute it shuts down. But if we start the car and have the stereo off, and then disconnect the battery, the engine shuts off right away.
Any ideas why this is happening?
Old Jul 2, 2013 | 08:09 AM
Phromethius's Avatar
is this stereo an aftermarket install? Those are notorius for draining batteries and having weird grounds or no grounds at all.
Also I always thought you could very easily disconnect the battery after a start and not worry about anything if you had a good alternator. The car doesn't draw from the battery after it has been started unless under a load I thought?
Either way there still sounds like something is broken in the chain of the circuit. There is no circular flow of electricity through your engine. I am not an electrician though. Just trying to propose some alternative thinking.
TallTom
57
Oct 14, 2025 05:16 PM
