bose back speaker problem today.
Old Jul 3, 2013 | 07:04 PM
theblackone3.5's Avatar
So, I was driving home today, when i was listening to my music. My back passenger bose system kinda went out. It still works but it is cracking like crazy. The only mod i have to my stereo is a pioneer AVH-P3200DVD. So i moved the sound to the front speakers only. I know how to remove them, but do i just need a new speaker or is something else? Thanks org members.
Old Jul 3, 2013 | 08:15 PM
Aflion's Avatar
Yeah, crackling out of one speaker usually means it's blown. You could check for bad connections, but it sounds to me like it's blown.
Posted from Maxima.org App for Android
Old Jul 4, 2013 | 09:31 AM
bump
Old Jul 4, 2013 | 10:06 AM
DennisMik's Avatar
I guess you're saying you lost both rear speakers at the same time. If so, I would suspect the head unit more than the individual speakers. Each speaker has its own output from the head unit, so if both speakers went out at the same time, I would say the problem is the head unit.
Old Jul 4, 2013 | 03:03 PM
No, just the back passenger speaker kinda went out. It works but it is crackling like crazy though. The other back speaker is working fine though.
Old Jul 4, 2013 | 03:21 PM
DennisMik's Avatar
OK, then it is most likely the individual speaker. While the head unit could still possibly be the cause, it's not that likely.
However, be advised that Bose speakers are unique. You cannot just put any speaker in to replace it.
I would suggest that you first test and verify that the speaker is bad before buying any replacement item. Unplug the bad speaker and then run jumper wires from the wire harness over to the driver's side speaker (you will have to unplug the wires from that one too) and see if the problem still exists. If the driver's side speaker sounds good, then the other speaker is bad.
There are 4 wires on the speaker. Every speaker will have a red and black wire on it, which are power for the printed circuit board that is part of the speaker and must be connected for the speaker to work. The other 2 wires are the audio signal wires to the speaker.
Old Jul 4, 2013 | 03:26 PM
Wait, i just cant buy a speaker off the forum and replace the bad speaker? Is that right? I find that hard to believe?
Old Jul 4, 2013 | 03:53 PM
DennisMik's Avatar
You can if it is made for the Bose system. But not all Maximas have the Bose system, so you must specify. I would still do the test, though.
Old Jul 4, 2013 | 03:57 PM
Well, what would the problem be if i pass or fail the test you mentioned early?
Old Jul 4, 2013 | 10:49 PM
Should i keep the back speakers stock or go aftermarket?
Old Jul 5, 2013 | 02:58 AM
Aflion's Avatar
If you go aftermarket on the rears, go full aftermarket. It just wouldn't balance well, especially with the risk of the bose speakers you have left blowing like the other did. You can sell the bose speakers to help pay for the aftermarket system, too.
Old Jul 5, 2013 | 07:32 AM
DennisMik's Avatar
What I wanted you to verify was that it really is the speaker that is bad. It is possible for the head unit to stop working on one channel.
Old Jul 5, 2013 | 09:12 AM
How do I check if the head unit went out? I think it would be that bc Both back speakers work but the back passenger side is just crackling terribly.
Old Jul 5, 2013 | 12:31 PM
DennisMik's Avatar
If you connect a good speaker to the passenger side wires and that 2nd speaker crackles, then the head unit is bad. If the 2nd speaker has good sound, then the original speaker is bad.
That's what I was trying to tell you back in post # 6. Unplug the passenger side speaker wires and using extension wires, plug them on to the driver's side speaker.
Old Jul 5, 2013 | 12:39 PM
Alright, Just need to find a bose speaker now?
Old Jul 6, 2013 | 02:37 PM
DennisMik's Avatar
Send a pm to Maxima_Joe and see what he has
http://forums.maxima.org/member.php?u=5900
or look in the classified forum
http://forums.maxima.org/4th-generat...-1995-1999-43/
Old Jul 6, 2013 | 07:35 PM
Where is the bose head unit located at?
Old Jul 6, 2013 | 09:12 PM
DennisMik's Avatar
Head unit is the more technical term for the thing in the dash that we commonly refer to as "the radio". Sorry for confusing you.
Old Jul 7, 2013 | 11:33 AM
then the back speaker is bad. Bc "the radio" works fine.
Old Jul 7, 2013 | 04:51 PM
Aflion's Avatar
Yup. Exactly. Whole drawn out conversation to come to the conclusion I posted that was ignored.
Old Jul 7, 2013 | 05:54 PM
Well, sorry if i offended you?
Old Jul 30, 2013 | 07:16 PM
How do i know if the speaker is going out or the amp itself?
Old Jul 31, 2013 | 07:01 AM
DennisMik's Avatar
Connect a known good speaker in place of the suspect one. If the problem still exists, then the amplifier in the head unit is bad.
Old Jul 31, 2013 | 08:20 AM
alright then, the speaker must be bad because the head unit is pretty much new.
Old Jul 31, 2013 | 08:28 AM
njmaxseltd's Avatar
Trouble shooting = FAIL ^^^
Swap the left and right speaker, see if the problem follows the speaker.
Trouble shooting = WIN ^^^
However, my vote does go to the speaker being the issue.
Old Jul 31, 2013 | 09:43 AM
BostonBarrett475's Avatar
Sounds like the speakers no good, if you have trouble/can't find a replacement one that would be perfect i suggest going aftermarket and you obviously if you have the cash. Well worth it to avoid the whole bose system. Get an amp to power the speakers (2 channel, or even 4 if you plan on adding more down the road) and 4 speakers, wire the RCA output of the headunit to the RCA input of the new amp and wire the speakers to that. Problem solved after a good tune. But that's only if you have interest in a more powerful/nicer sounding sound system. And that's how to properly go "aftermarket" with speakers. The cheap easy alternative would be to simply replace the speaker that sounds blown.
Old Jul 31, 2013 | 01:57 PM
Its just the back passenger speaker that is about to blow
MikesChevelle
Nov 23, 2024 11:17 AM
JRod28
Dec 29, 2023 09:56 PM
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
Mcnabb34
Aug 11, 2015 08:45 PM
MikesChevelle
Aug 9, 2015 11:50 AM
