Idle ?
Old Jan 14, 2002 | 10:29 PM
KFL's Avatar
KFL
Idle ?
In my friends 97Max 5spd, when slowing down to pay a toll, puts car in neutral the idle of course drops but it goes a tad under 1k and then bounces back up to 1k if this normal?shouldn't it just got to 1k and sit there
Old Jan 14, 2002 | 11:15 PM
95emeraldgxe's Avatar
well......i guess its ok......cause liek idle for me is like 800 rpm about.....but if i move the steering wheel around it jumps to 1K....so maybe that may have happened?
Old Jan 14, 2002 | 11:19 PM
sbslacker's Avatar
Re: Idle ?
Was the car cold? RPM's seem to be a bit jittery (as well as slightly on the high side) when the car is still waking up
Old Jan 14, 2002 | 11:22 PM
Cumalot's Avatar
lol...I know what you mean. My idle is really messed up. It's around 1k at startup, but goes back down after the car is warmed up. Could be the cold weather because this didn't happen in warmer weather.
Old Jan 15, 2002 | 12:00 AM
Nismo's Avatar
When I cleaned my TB it got rid of all my idle problems. could it be the ECU re adjusting the idle speed?
Old Jan 15, 2002 | 10:38 PM
KFL's Avatar
KFL
I cleaned it out part of the throttle body via pc valve carbon deposits. Should I try and cleaning it via throttle body itself.
Oh this wasn't at start-up I know most cars go through the whole high idle and then it settles. We were driving it for about 1hour+ and slowed down for a toll. I'm stumped
Old Jan 16, 2002 | 07:15 AM
HondaKiller718's Avatar
THE ANSWER
When it is cold outside it takes a little bit more for the engine to warm up to normal operating temperature. So inturn the engine rev's higher to get your engine warmer faster. This lets you warm up the inside of the car for comfort and the engine for optimal oil protection. But once the correct temp is reached the idle drops down to the 600 rpm to 800 rpm range. This is normal.
Old Jan 16, 2002 | 07:16 AM
That's power steering in action.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
