99 Maxima no Voltage
Old Jul 12, 2013 | 08:12 PM
dancad's Avatar
My 99 Maxima has 12.6 volts at the battery yet no lights, dash lights or anything else has any power.
Things started to go wrong when I would turn the low beam light switch on. All power would dump when I would do that. Charged the battery and with the light switch off, car starts and runs fine.
With engine off, when I turn the headlight switch on to low beam the power dumps again
Changed the battery and now I have absolutely nothing. The Security light does link as normal and that's it
I have 6.5 volts at the power feed to the ignition switch
Any ideas
Old Jul 12, 2013 | 08:35 PM
D I R T Y I 3 0's Avatar
Any ideas
Might be the alternator man
Old Jul 13, 2013 | 12:30 AM
tosheto's Avatar
Start the car and measure the battery voltage. If it is around 14.5V then your alternator is good. If it is much lower then you need a new one because this one is toast. Check your fuses. Maybe the wires of the headlights are messed up and kill your battery.
Old Jul 13, 2013 | 05:36 AM
njmaxseltd's Avatar
There are additional power lines that connect to the battery + terminal.
Remove them, clean and inspect the ends for corrosion.
Old Jul 13, 2013 | 07:35 AM
DennisMik's Avatar
Definitely check the main 120 amp fusible link that is in the middle of the fuse box next to the battery. The alternator won't charge and a lot of things won't work, but if the horn blows, then the fusible link is OK.
Old Jul 13, 2013 | 02:20 PM
Climaxx's Avatar
THIS.
I'm willing to put money that this is your issue. The alternator isn't even a factor since OP said it does this even with the car off.
Balkins
Feb 1, 2016 12:45 AM
doobadoo
Aug 15, 2015 06:43 PM
bassmann
Aug 13, 2015 10:13 PM
Superbform
Aug 11, 2015 08:10 PM
