1997 Nissan Maxima - Vibrating please help
Old Jul 29, 2013 | 04:16 PM
art23's Avatar
I have gotton all of the following done:
Replaced the air flow sensor
Tune up -- changed spark plugs
changed the harness to the c-pack
My car is still vibrating with a noise (in park, at red lights); I smell fumes and can barely accelerate past 20 miles for a few seconds.
Old Jul 29, 2013 | 04:46 PM
BrooklynCyclone's Avatar
Coils my dude check them one by one ,by unplugging each while the car is on there should be a sticky for this .....
Old Jul 29, 2013 | 05:07 PM
art23's Avatar
Two coil packs were put on...
Old Jul 29, 2013 | 06:36 PM
Fakie J Farkerton's Avatar
It's likely your MAF and I'm in before moved to 4th gen section.
Old Jul 29, 2013 | 08:21 PM
art23's Avatar
I changed that out too.
Old Jul 29, 2013 | 08:22 PM
Originally Posted by art23
i changed that out too.
oem?
Old Jul 29, 2013 | 08:25 PM
art23's Avatar
oem?
Used part from the junkyard.
Old Jul 29, 2013 | 08:26 PM
Read the CEL codes and report back.
Old Jul 29, 2013 | 08:35 PM
art23's Avatar
Ok...
Old Jul 30, 2013 | 03:49 PM
art23's Avatar
Codes:
P0340
P0443
P0325
P0150
P0100
P1335
Old Jul 31, 2013 | 06:55 AM
DennisMik's Avatar
Here's what those codes are:
P0100 - MAF Sensor
P0150 - O2 sensor, bank 1 sensor 1
P0325 - knock sensor
P0340 - camshaft position sensor
P0443 - EVAP canister purge control solenoid valve
P1335 - crankshaft position sensor (REF)
Your car can't accelerate because it is in "limp mode" because of the P0100 code - the MAF. That junkyard MAF is evidently no good.
Clear the codes and see what comes back. I think most of them will. Get a good MAF in the car, clear the codes and see what comes back. I'm thinking the P0100, P0150, P0325 and maybe the P0340 will be gone.
Old Jul 31, 2013 | 05:57 PM
art23's Avatar
P0100 - MAF Sensor
I'll update soon...thanks.
Old Aug 3, 2013 | 04:20 AM
art23's Avatar
P0100 - MAF Sensor
Is the air flow meter the same as the MAF sensor?
Old Aug 7, 2013 | 03:13 PM
art23's Avatar
After resetting the codes...drove the car for a while with no problems--then the car started vibrating and can barely accelerate. Could this be a wiring problem?
Old Aug 7, 2013 | 06:05 PM
Get another OEM MAF IMO...
AND clean it with MAF cleaner before installing.
Old Aug 8, 2013 | 10:02 AM
Phromethius's Avatar
just to clarify for you in case you need it. The MAF (Mass Air Flow) sensor is the black plastic square box section of your intake INBETWEEN the air filter and your throttle body.
Old Aug 8, 2013 | 10:08 AM
I know your trying to help, but back reading does wonders.
Unless he replaced something he thought was the MAF, he said he already got a used one at the junkyard and it appears to be faulty as well.
It could just need a cleaning, but sounds bad.
Old Aug 9, 2013 | 04:33 PM
lsn8088's Avatar
I had a similar problem on a smaller scale. Coil pack was the problem. OEM coil packs are more reliable. I had to return 1 new aftermarket coil pack that was bad from the get go. It's best to test each one with the vehicle on.
Another issue I fixed was replacing the rubber boot that attaches to the MAF. Sizable leak by the coupler and all dried out. G'luck.
Old Aug 10, 2013 | 11:15 AM
art23's Avatar
Got the MAF cleaned this morning--so far it's driving good. Do I still need to reset the codes to see what it reads now?
Old Aug 10, 2013 | 01:18 PM
DennisMik's Avatar
Codes will go away by themselves (IF the problem is fixed) but it takes several driving trips amounting to anywhere between 50 and 100 miles. It would be faster if had the ECU reset.
Old Aug 11, 2013 | 08:06 AM
art23's Avatar
The MAF cleaner isn't working. The car started vibrating again. When I stop at a light, I can hear a noise from under the hood and and still smell fumes.
This is really frustrating because I can't fix cars. I have someone doing this for me. He told me to take it in to get a diagnostic because he can't figure it out. He said because it runs good for a while then bad is something with the electrical.
Old Aug 11, 2013 | 09:27 AM
This
You can post a wtb here in the classifieds for one that someone has tested and confirmed working.
Good luck
Old Aug 12, 2013 | 10:17 AM
TurboA32's Avatar
Try cleaning both crank sensors
Old Aug 12, 2013 | 06:30 PM
art23's Avatar
Would the MAF cause the car to drive normal for a while then back to vibrating?
Old Nov 10, 2013 | 08:12 AM
art23's Avatar
Just to update: I put a new MAF on and it still vibrates and misfires. Any suggestions on what may be causing this?
Old Nov 10, 2013 | 09:46 AM
Alaskus's Avatar
P0100 - MAF Sensor
You changes the MAF as you said. (2x - that does suck)
are you still pulling codes?
also you said smell and misfires:
to be clear, what kind of plugs did you put in? NGKs are highly agreed upon here at the org.
You changed 2 coilpacks. Coilpacks are suspect as they can cause vibration and misfires. But, if you are not using NGK plugs, this becomes less likely. One or more of the original four could be bad as well? Possibly... one of the two new purchased might be worn or out of range (if used, and aftermarket are known to come bad a percentage of the time)
Smell - Fuel smell? misfire might indicate injectors. (what kind of gas do you use? 87, 89 or 90+?) if not already bump it up to highest and add a bottle of techron/lucas to clean it up. if things clear up a bit then you might have a weak injector. This might help. When was the fuel filter last changed?
TLDR;
Check the codes again, if any and get back to us.
What kind of plugs were they?
Do the coilpack test again
Gas Quality? Run an additive..
Last time Fuel filter was replaced?
Dont do all this at once - but step by step so you find the issue and solve it
Old Nov 18, 2015 | 04:03 AM
hthoang0118's Avatar
Do you get any CODE? Did you do a OBD scan?
There are many symtoms:
1- Injector
2- Mass Air Flow
3- Ignition Coil
4- Spark Plug
Please u see any check engine light on?
Old Nov 18, 2015 | 04:04 AM
Did you see check engine light on?
Did u see check engine light on?
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
jchronis2552
Aug 13, 2015 07:48 AM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
