help with reds\clears
Old Aug 5, 2013 | 09:25 AM
bumpypickle's Avatar
I ordered some new red\clears for my 97 4th gen and the 2 corner pieces fit perfectly with no problems but the 2 inner pieces don't aren't flush and its really bothering me. The left side isn't so bad as the right.
Old Aug 5, 2013 | 09:52 AM
Amerikaner83's Avatar
you've gotta get yourself a dremel and grind off about 1/4 inch of the circle the studs mount to. See this pic I took that shows the difference:
Bet they look like this, right?
You can see where the lip touches the trunk lid...
After dremel work:
ALSO: Get yourself some NON-capped nuts for those studs. The stud length is longer so the OEM capped nuts will NOT fit. They're the 8mm nut - M4 or 5 I believe. Take one to the hardware store and compare to be safe.
Nice and flush afterwards
Old Aug 5, 2013 | 10:44 AM
Oooh okay yeah I was looking at that part of the tails and thought that obviously was the problem but I wanted to make sure before I returned them to the person I bought them from, thanks man I appreciate the help!
Old Aug 5, 2013 | 01:26 PM
yeah don't waste your time with returning them...it's apparently pretty common.
Dremel it down and you're good to go my friend
Old Aug 5, 2013 | 03:54 PM
Climaxx's Avatar
After dremel work:
^ post of the day
Old Aug 5, 2013 | 04:10 PM
ShocknAwe's Avatar
couldnt you just use an open ended nut?
Old Aug 5, 2013 | 04:13 PM
You mean a non capped nut? Like I mentioned? Not sure what an open ended nut is
Edit...looked in google and what I called a non- capped nut is the same as what you call open ended, apparently.
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
uttadms31
Sep 30, 2015 05:24 AM
